Hey guys I'm just stripping down my Magnum engine as I think I've broken a ring landing on the piston. I'm still running the standard Magnum pistons. Is there a forged option that I can use on the factory rods that won't break the piggy bank
Hey guys thanks for the replies,OP, do you have any idea why the land broke? Often, this is caused by detonation. How hard are you using your engine? Using any nitrous? Turbo? More info would be helpful.
The pistons above are not cheap. Hyper pistons are reasonably strong and stronger than regular cast. I've used them in a turbo engine at 14 psi boost with no issues. So that may be an alternative. Silvolite has a 3222HC hyper piston....although the catalog says "Not intended for racing applilcations" so I cannot what that means exactly.
KB232 would be a better hyper piston.... But you have to examine gasket thickness and work on overall compression ratio, as these will stick out of a standard Magnum deck by a few thousandths and are a lot higher in the bore than standard Magnum pistons.
You did a bang-up job there! I'm gonna guess that those pistons experienced detonation too, and the shock load hammered the pistons hard enough for that skirt breakage. The pistons are already seeing some significant side thrust even 15-20 degrees after TDC.Ok so piston landing would be from detonation but I don't know why the skirts are broken
I'm in the same boat with my 5.9 magnum turbo, looking for forged slugs. Are you saying you've used the KB hypers in a boosted app?I do not know of an off the shelf forged piston with a quench dome on the intake side and a step or dish on the spark plug side
flat tops do what yours did with any little hiccup
detonation will break anything- did you say which side of the piston?
as I said I'd pick one of the KB hypers that fits your cr needs and either use it or get a forged duplicate made- done it lots of times
I have used hypers in a turbo application with no problems. Mitsubishi 2.6L (half of a 318 dispalcement) running 14-15 psi boost; rally racing and hmmering on it all the time with all sorts of premium pump fuel from gas stations in the hinterlands and all sorts of atmospheric situations. The key was to stay out of detonation. Hypers will survive better than cast for that, but not as forgiving as forged IF you get into detonation.I'm in the same boat with my 5.9 magnum turbo, looking for forged slugs. Are you saying you've used the KB hypers in a boosted app?
