what are the strongest gear's I can buy?
Transmission and Drivetrain Tech
  1. BARRACUDA340S
    BARRACUDA340S Well-Known Member
    1,011
    0
    May 13, 2004
    MT PLEASANT IOWA
    Local Time:
    11:26 AM
    Is there any scientific proof to this or is this something like a spark plug debate? I need some strong gear's if I beef everything else up.
  2. BillyBBad
    BillyBBad Well-Known Member
    194
    0
    May 22, 2004
    Beaufort, Missouri
    Local Time:
    11:26 AM
    I run a Richmond Gear, I have NEVER had any problems with them.
    But then again your runing WAAAAAY more HP :lol:
  3. rabius75
    rabius75 Well-Known Member
    543
    1
    May 22, 2004
    Dallas, GA
    Local Time:
    11:26 AM
    how about you get them cryogenically treated :)
  4. BOSS VEGA V8
    BOSS VEGA V8 Senior Citizen
    290
    8
    May 13, 2004
    Simi Valley California
    Local Time:
    11:26 AM
    these might be strong enough!!!!!!!!!!!!!!!1 :lol: :lol: :lol: :lol:
    [​IMG]
  5. BBLM23
    BBLM23 Well-Known Member
    459
    0
    May 22, 2004
    Greenville, SC
    Local Time:
    6:26 AM
    The ring and pinion I broke a tooth off of was a Richmond. My quickest run was an 11.88 and I run an auto... Freak thing?
  6. six pack
    six pack Well-Known Member
    424
    0
    May 22, 2004
    Alberta Canada
    Local Time:
    11:26 AM
    I have never heard anything bad about Richmond gears.
    You also need to consider that your car may be fast but it's not that heavy which will mean less strain on the gearset compared to the Hemi car in the next lane that is as quick but another 1000-1500 lbs heavier.
    Food for thought.
  7. HawaiiDuster
    HawaiiDuster Well-Known Member
    2,601
    62
    May 22, 2004
    Honolulu & Las Vegas
    Local Time:
    3:26 AM
    I used to run a Zoom 4.56, I've never tried the Richmond gears yet. I'm going to need to find a new set soon so I'm interested to hear what others have tried. The one thing that I have noticed is that no one has made a Pro gear only street gears.
  8. LAR_414
    LAR_414 Member
    20
    0
    May 25, 2004
    Pittsburgh, PA
    Local Time:
    11:26 AM
    I've run Richmond and US Gear. Both are very strong. The US Gears were 29 spline vs 10 spline for the Richmond. So they take different yokes. The only difference I noticed was that the US Gears were noticablly quieter than the Richmonds.
  9. ZEATER
    ZEATER Member
    18
    0
    May 27, 2004
    Local Time:
    11:26 AM
    :lol:
    Just make sure you order the street gears. Some race gears are not made to handle the heat generated on sustained street use and can become brittle. It will be interesting to see just what broke inside the carrier. It may not have been the gears.
    Since you basically have no traction on the street I would think that the wheel hop is the problem. It would be pretty violent through the shift.
  10. NewABodyFan
    NewABodyFan Active Member
    25
    0
    May 24, 2004
    Salt Lake City
    Local Time:
    11:26 AM
    I truly believe this to be a fact. After you go below 11.5 and your launching hard, you best be putting a new set of gears in a 8.75 rear every year at the start of the season. If not, your going to break them. You might get away with a season and a half, or two, if you don't run every week, but it is going to happen. Just bite the buillett and spend the money for the new gears, and keep your car running. I see this happening all the time.
    Earl
  11. ZEATER
    ZEATER Member
    18
    0
    May 27, 2004
    Local Time:
    11:26 AM
    These gears weren't raced as far as I know and definately not raced with the 4 speed. I still think this is more of a wheel hop problem as Brett has zero traction on the street and violent wheel hop. I think pinion angle may also be a problem.
    I'm sure we'll get it straightened out.
  12. HawaiiDuster
    2,601
    62
    May 22, 2004
    Local Time:
    3:26 AM
    They only make street gears for the 8 3/4. I've never seen a 8 3/4 pro gear made yet :( Hopefully soon.
  13. GotDart
    GotDart Well-Known Member
    1,393
    9
    May 22, 2004
    Austin, TX
    Local Time:
    5:26 AM
    What about Strange gears? Anyone know if they are any good?
  14. DARTSPORT
    DARTSPORT Well-Known Member
    411
    33
    May 23, 2004
    Ringtown, Pa.
    Local Time:
    6:26 AM
    I have Richmond gears in mine now. The car weighs 2770 with driver, currently launching at 3600rpms on the 2-step, with converter flashing to 5000rpms, with a trans brake.. Also ran Richmonds in my old car. the only time that I had any trouble with a ring gear, was about 8 years ago when I used one of my other cars with a 4-speed, and slicks. I was side stepping off the clutch at the starting line at 6ooorpms, the ring gear didn't like that!! Only lasted about 20 passes untill I nocked 2 teeth off the ring gear!!
  15. six pack
    424
    0
    May 22, 2004
    Alberta Canada
    Local Time:
    11:26 AM
    Forgot to mention I broke an axle shaft clean with a fairly mild 440 I had in my High School Challenger. :(
    Maybe you broke the spiders.
  16. 70Barracuda
    70Barracuda Well-Known Member
    141
    1
    May 28, 2004
    Beaverton, Orygun
    Local Time:
    11:26 AM
    Dana 60 and be done with it!
  17. DusterBoy15
    DusterBoy15 THE WISE(guy) MEMBER
    1,668
    0
    Apr 7, 2007
    san jose CA
    Local Time:
    5:26 AM
    are motive gears any good?
  18. dgc333
    dgc333 Well-Known Member
    4,125
    25
    Jan 12, 2005
    Pembroke, MA
    Local Time:
    6:26 AM
    FWIW, race gears are softer than street gears. The reason is the hard gears are needed for long term wear on the street and the soft gears will absorb shock better on a race car but at the expense of accelerated wear.
  19. 340mopar
    340mopar Sorgermotorsports
    3,676
    15
    Jan 25, 2006
    Soap Lake, WA
    Local Time:
    3:26 AM
    I agree with dgc333 as your power goes higher you need "softer" gears not "harder" gears.
    Chuck
  20. 7172 duster
    7172 duster 7172 duster Legendary Member
    1,015
    10
    Nov 29, 2005
    Hodgenville Ky.
    Local Time:
    5:26 AM
    200 passes they need to be changed if 8.75. dana 60 is a lot stronger . 10.52 @ 127 . 1.43 60 ft
    [​IMG][/IMG] [​IMG][/IMG]
