Man ,you sure have a lot of leg room in there.Almost done with the interiorView attachment 1715540679
One step at a timeMan ,you sure have a lot of leg room in there.
Man, you need to be careful, you about poked a hole in your head.I also ran into the lift this morning. What an idiot.View attachment 1715541870
I finally got my Hotchkis A body springs yesterday.
I ordered them in January!
Today I removed the current SS springs from the car.
Went to install new springs...supplied bushings I can't get on old shackle shaft.
The holes are smaller by a bit and old shackle has corrosion attached to both bolt shafts.
I cleaned them up with file and sandpaper, but no dice.
Ordered new shackles.
Mounting bracket that came with springs is wider than stock. Spring moves sideways abt 1/4 to 3/8 of inch.
I don't think that's right.
Tried to find Hotchkis ph number but can't get into there website. I went there yesterday and was able to download instructions.
View attachment 1715541888 View attachment 1715541889View attachment 1715541892 View attachment 1715541891
Well I will try again tomorrow.
Working on the brake lines on rear end, before putting in new fuel tank .Putting fuel tank in on creeper sucks ,lift i used to have spoiled me! Year one tank,sending unit w/ gasket& locking ring, filler neck grommet and tank pad $249.00 Taiwan tank Brake lines from summit
Installing all my labels today. Not posting the vin tag on the drivers door thou.
