What Cup Push Rod
1973_Scamp
San Jose
Hello Folks
It is a 1985 Roller Block with stock lifter.
302 heads
Comp Camshaft XR268HR-10 Hydraulic Roller
273 Adjustable Rocker
I've seen this set up somewhere but could find it.
I'm looking for cup push rod with appropriate length that would go with this set up.
Please advice with link if possible.
Thanks
Scamp
Non factory cam and adjustable rockers, I'd buy a push rod length checking tool and measure.
Smith Brothers will make whatever you need.
OH, here we are. I guess I have the same setup except re-ground cam. Not together yet Do the 302 heads have the large pushrod holes? Otherwise you will have to re-work them.
I have a couple of extra 273 flat tappet solid lifter pushrods. What I'm hoping to do is to "burn" one of them to make a checking pr, and hopefully shorten my own. I have a lathe, so hoping to turn down the PR on one end (probably the cup because you can "get ahold" of them" to release the end and clean it up. They are pressed in and either staked or spot welded. Then shorten the tube and press them back together.
I should get busy "down there" and see if I can "do one" of them.
I've found 1987 5th Avenue push rod from roller block with roller lifter using standard rocker measured at ~ 6.5". How about Cran 69628-16? It is measured at 6.58"
