What did you order for your car today ?
318willrun
Utube channel 318willrun
I'm here
  1. oil pan and pickup tube
  2. motor mounts
  3. POR-15
My 2004 Dodge 3500 truck is in the shop getting about $3,000 worth of suspension and brake work. That has my "fun" car spending on hold for a couple months.....
Nothing. My cars are in mid season form, if I need anything, it probably won’t be until winter until I can get to it, so I’ll just drive em as is for now!
Ok, maybe I should order that oil pump and button the 340 up and get that done. You’ve convinced me rabbit, I’ll look for Rocky in the city!
That bearing works great. Need to sand out the inside of the tube so the it will slide in. Just did this on my Duster. Works great and is really smooth
Can't take the heat. I give up, can't get the reliability from the factory orig parts; overheated, stalled on the line and lost race. Ordered a Black Magic fan and electric water pump.
Lots of compression and horse power creates heat. At the line no air moving through the radiator.
Engine parts for my sons 2.2 turbo Daytona we are building.
Dropped head and fly wheel off at machine shop for a re fresh.
Spare top radiator hose for the 66’ 273
I added a rear plow to the plow truck, so I ordered a back up camera for it
The JVC double din head unit has an input for it, and the camera I ordered should replace the stock tailgate handle
Ya, was marginal already, this year driving to the track for the first time since I was a teenager and there is a heat soak aspect. Then it seems like it's been 90 deg every time we've gone to the track this year; 30 years ago it seemed like we were lucky to see a max of 70 deg anytime up here in the Seattle area. In this case the guy that ran before us leaked on the track and there was a delay to clean, and that was too much.
My dads first new car was a laser, and my first car was an 84 Daytona turbo. It was a basket case and I never got it to run. They’re neat little cars
Hump Hugger armrest and Drink Holder Fits Fard MustardStain... Should fit in My early Barracuda!
90 * heater hoses,90* hose couplers.And crimp tool for A/C hoses,unless I can borrow one locally.
Power brake booster, master cylinder, Dot 5 silicone fluid for my 96 ACR Neon. Bumpers for the 68 Barracuda from Tri-City Plating.
Already have a pile for parts to install on the GTS. I did order a rear sway bar and Bilstein 5100 shocks/struts for my 16' F-150.
Just a handful of stainless screws, bezels, and other hardware for installing the vinyl floor in the D-150.
Some -10 AN fittings, a coil of brake line along with some fittings and a master cylinder pushrod.
