yellow rose
Overnight Sensation
Is this plug lean, rich or just right? And if it’s anything, where is it rich, lean or just right, as in idle, cruise or WOT?
TIA
TIA
To me it looks lean on Top End,Rich at MId range and JUst right at LOw End. Thats my opinion and I'm stickin to it !
pig rich at cruise and WOT. tuner needs help.
I would ask a plug reading Guru...
That gets a collet to hold it in? What is it out of?
I am going to guess the power valve is 1/2 of idle vac. Needs smaller main jets too.
Since know one else want to make a *** of them thyself........uwh uwh pic me pic me!!!!!
From what i under stand of plug reading in the lower ceramic it is totally full throttle fuel and the thinner and lower the line the learner it is. So with that theory.
I say jetting, or power valve channel restriction need drilling out so that a jet can be installed to tune it.
It could be air bleed side of it too but just don't understand that stuff enough to even comment on it
as far as mid range and idle.....can't even guess on that.
Woo Hoo!
And i thought i was going to have to put the dunce cap on, and sit in the corner.
But something tell me there is more to this story...............
What is the timing at cruise? What vacuum? Any vac advance involved?
On my wife's car with fuel injection it took a lot of messing with timing as well as fuel to get rid of idle and in town low rpm surging. What it ended up wanting was the exact opposite as what I would have guessed.
Oh, what do the rest of the plugs look like?
Looks like it was turned down in a lathe for inspection.That gets a collet to hold it in? What is it out of?
All the plugs are very close. No vacuum advance. I don’t have the distributor curve sheet right in front of me but IIRC the timing is all in by 2200. It has 18 initial on it (at about 750 RPM) and at a 900 RPM in gear idle it has 22 degrees. It has 41 degrees total timing.
