What is this thing
dartgts340
Massachusetts
Ok looked all over the wiring diagram. Can someone please tell me what in the world the resistor looking thing on the back of the instrument cluster is.. I don't have pic yet but basically looks like a resistor with one wire coming out.. Is this a ground and where in the world does it hook up to. I am not able to put a picture up but will as soon as I can. Any help would be greatly appreciated..
It's a capacitor for radio noise suppression. The electromechanical regulator for the instrument panel can cause clicking sounds in the radio. Going to a solid state regulator (make your own or buy your own) should eliminate the need for that capacitor.
Does it look like this?? The bottom piece? I have a '73 Scamp and was wondering the same thing...Nice car by the way!!!
The lower one is the one that I am talking about.. Thanks been trying to figure it out.. Car is so close I can taste it and now making sure electrical is all ok.
Ounce again thanks and FABO members teach me something...
Lower piece is a "condensor" or "radio noise suppression cap" see http://www.allpar.com/history/mopar/electrical2.html about halfway down.
If you retrofit to a solid state 5V regulator, you can pitch the condensor and the shoddy, 60 year old tech regulator for something that'll probably never die as long as you put a big enough heat sink on it. The link given earlier will not "bolt in" on a mopar, unless you're OK with just jamming those ring terminals down into some slots. It took me about an hour to wrestle the damn dash out, and about 5 minutes (4 minutes of waiting for my iron to heat up, two of those spent eyeballing a bag of capacitors to find an appropriate reading and figure out which lead was negative) to solder one of these in from "bare parts" in Radio Shack bags (about $15 total investment if you include a new spool of solder), and then a half hour to wrestle the stupid dash back together. If you check out the article, you'll see that the screw hole the condensor tab uses is the perfect place to mount the heat sink and regulator, it's about 18 inches of wire. You're honestly not buying much saved time with that kit.
I also took the opportunity of the dash being out to replace all the 194 instrument bulbs and their 5/8" 194-type black socket housings - the bulbs were $5/10 and the sockets were $10/10, and used some scotch brite and vinegar to "brighten up" all the connections around the lamp sockets. I then dabbed some dielectric into the sockets and onto the tab contacts. It's probably overkill but its cheap insurance against crappy flickery dash lights and mystery gauge waves.
One of my "main instrument harness bundle" pins was a bit wobbly so I put a plug on it to hold it straight and soldered just a tiny bit around the base, which seems to have stabilized it. Hopefully I never have to take this off ever again.
