What should cold lash setting be?
I know Stock Eliminator guys who run solids even if they
are on hydraulic profile camshafts, they set them at
.004 which scares me. I was just talking to a well know
engine builder out of Arizona this week and I asked:
Are you not scared of burning an exhaust valve for it
being on the seat a shorter time to cool?
He said it was never a problem as he is way smarter than
I am (I am just a hobbyist)! Our cars only run for a couple
minutes so I assume he is correct. But it still scares me.
Running close to zero lash with solids lifters on a hydraulic cam has been done forever. But all the details are critical and needs to be right.
Not to offend anyone, but I would not recommend it to most of today’s hobbyist.
during the last few Dyno pulls we tried tightening the lash to see what my engine liked, I think I ended up tightening the lash .006 - .008 on both intake and exhaust and it picked up power.
Not a big gain but it was around 8-10 HP.
I would have liked to do more tuning but I was already around 25 pulls.
The devil is in the details in the balance of the motor build. I have seen the opposite when comparing average hp in the shift-to-shift recovery rpm range.
I edited my post earlier because I didn't format my sentences very well, then I completely forgot to add in the fact that " my smallish camshaft" responded well to the tighter lash.
There's the devil in the details.
That cam is 264-268 @.050 in a near 13.0:1 470 cubic inch low deck.
our gk stocker cam is at .006 cold, makes it .004 hot, seems to work ok, no problems, had a comp stkr cam called for .006 lash on intakes, zero lash on exh, int was a solid lobe exh was hyd lobe. just food for thought
It’s telling you it wants that bigger cam you have:poke:
And in my case, my motor could probably benefit from a smaller cam.
Loosening lash make the cam look smaller to the motor, but also makes it act like it has faster lobes.
Up until a year ago , I never really put much thought into lash and doing testing on the dyno really made me start thinking a little further into everything going on in the engine.
Air cooled VW guys run them at .000. They just warm them up in the pits.
