bernieca
Does anyone know what the center bore (hole) size is on a SBP front rim for a 72 Duster with disc brakes. Thanks!
Bore size? are you referring to the hub?Or the piston bore? cylinder bore?a little more info please it may help you find an answer .
Referring to the hub. I am looking to determine what size the center hole in the rim needs to be to fit over the hub on a 72 duster with disc brakes. Hope this clarifies. Thanks.
Sorry i runs lg pattern but can check i do have factory small pattern rim i will measure the whole for you hop that helps.
The bore is about 2.3" on the small bolt pattern wheel. Couldn't get my calipers on square that's why I say about.
I have a rim that wouldn't fit and it was 2.3" so it must be larger. It has the Kelsey Hayes front disc brake set up so it is larger than drums. Unfortunately the car in in for paint and I cannot access it to measure the front hub.
Maybe it is 2.85"
Anyone know for sure?
Maybe it is 2.85"
