Further ahead than I was before, think I got a few bits of good info to build on.@273 have you learned anything on this thread?
Air flow and it's speed (velocity) obviously plays a big role. But if you look at the acceptable velocitiesSeems to me the focus has been on velocities flows etc.
I'm not convinced velocity is an input or an all important variable.
It does cover a wide range 240-320 fps, If you calculate that out to port cc size for 300 cfm that's about 245-180 cc which is a pretty big range, and Trick Flows are 190 cc putting the on the small side and fairly high velocities 308 fps. If these are correct seems like not enough port cc is generally more of a problem.
That definitely play a role at particular rpms.I haven't seen much about runner length optimization for a given combo. That's a big deal.
When you calculate a lot of these engines aspects out you see a lot of symmetries.You seem to love your formulas.
They tend to make torque.Maybe a tunnel ram should be part of the "equation".
