What would you build if limited to 372ci - with boost as an option
So these are the class engine sizes you can run ?
What class the car running under ?
Is it BVGCC ?
The first letters of a car’s classification usually reflect the engine’s displacement but sometimes are even more specific. The most common engines found at Bonneville are pushrod V-8s for the larger engine classes and motorcycle engines for the smaller engine classes; however, virtually anything goes. A Mopar 440 big-block with its factory bore and stroke is actually 439.72 cubic inches, putting it right at the upper end of the allowed displacement in the B class. A Supra’s 3.0-liter 2JZ engine would place it in the F class.
Cubic InchesLiters
AA501+8.210+
A440–500.997.210–8.209
B373–439.996.112–7.209
C306–372.995.015–6.111
D261–305.994.277–5.014
E184–260.993.015–4.276
F123–183.992.016–3.014
G93–122.991.524–2.015
H62–92.991.016–1.523
I46–61.99.754–1.015
J31–45.99.508–.753
KUp to 30.99Up to 0.507
VEHICLE DATA CODES
CARS
ENGINE CODEENGINE CLASSENGINE DISPLACEMENT
101ΩENGINES USING THERMODYNAMIC CYCLE OTHER THAN OTTO
102AA501 CID AND OVER
103A440 THRU 500 CID
104B373 THRU 439 CID
105C306 THRU 372 CID
106D261 THRU 305 CID
107E184 THRU 260 CID
108F123 THRU 183 CID
109G93 THRU 122 CID
110H62 THRU 92 CID
111I46 THRU 61 CID
112J31 THRU 45 CID
113K30 CID AND UNDER
114E1/T1/S1ELECTRIC/TURBINE VEHICLE WEIGHT I
115E2/T2/S2ELECTRIC/TURBINE VEHICLE WEIGHT II
116E3/T3/S3ELECTRIC/TURBINE VEHICLE WEIGHT III
117UFOR UDT,MDT,HH2 & HH3 BODY CLASSES
120XOOVERHEAD VALVE & FLATHEAD INLINE
121XFPRODUCTION FORD/MERCURY FLATHEAD V-8 ENGINE
122XXFXF ENGINE W/OVERHEAD VALVE CONVERSION
123XXOXO ENGINE W/SPWCIALTY CYLINDER HEAD
124V4PRE-1935 “AMERICAN MADE” FOUR CYLINDERS
125MMIDGET VINTAGE ENGINE
126V4FPRE-1935 “AMERICAN MADE” FOUR CYLINDERS FLATHEAF
BODY CODEBODY CLASSBODY TITLE
301BFALTBLOWN FUEL ALTERED COUPE
302BFCCBLOWN FUEL COMPETITION COUPE
303BFLBLOWN FUEL LAKESTER
304BFMRBLOWN FUEL MODIFIED ROADSTER
305BFRBLOWN FUEL ROADSTER
306BFSBLOWN FUEL STREAMLINER
307BGALTBLOWN GAS ALTERED COUPE
308BGCBLOWN GAS COUPE
309BGCCBLOWN GAS COMPETITION COUPE
310BGLBLOWN GAS LAKESTER
311BGMRBLOWN GAS MODIFIED ROADSTER
312BGRBLOWN GAS ROADSTER
313BGSBLOWN GAS STREAMLINER
314BGTBLOWN GRAND TOURING SPORTS
315AIRAMERICAN IRON ROADSTER
316BSTRBLOWN STREET ROADSTER
317BVFALTBLOWN VINTAGE FUEL ALTERED COUPE & SEDAN
318BVFCCBLOWN VINTAGE FUEL COMPETITION COUPE & SEDAN
319BVGALTBLOWN VINTAGE GAS ALTERED COUPE & SEDAN
320BVGCBLOWN VINTAGE GAS COUPE & SEDAN
321BVGCCBLOWN VINTAGE GAS COMPETITION COUPE & SEDAN
322DTDIESEL TRUCK
323EELECTRIC VEHICLE
324FALTFUEL ALTERED COUPE
325FCCFUEL COMPETITION COUPE
326FLFUEL LAKESTER
327FMRFUEL MODIFIED ROADSTER
328FRFUEL ROADSTER
329FSFUEL STREAMLINER
330GALTGAS ALTERED COUPE
331GCGAS COUPE
332GCCGAS COMPETITION COUPE
333GLGAS LAKESTER
334GMRGAS MODIFIED ROADSTER
335GRGAS ROADSTER
336GSGAS STREAMLINER
337GTGRAND TOURING SPORTS
338BMPBLOWN MODIFIED PICKUP
339BMMPBLOWN MODIFIED MID-MINI PICKUP
340PMPPRODUCTION MID-MINI PICKUP
341MMPMODIFIED MID-MINI PICKUP
342MPMODIFIED PICKUP
343MDTMODIFIED DIESEL TRUCK
344MVOTMIDGET VINTAGE OVAL TRACK
345PPPRODUCTION PICKUP
346PROPRODUCTION COUPE & SEDAN
347PSPRODUCTION SUPERCHARGED
348STRSTREET ROADSTER
349UDTUNLIMITED DIESEL TRUCK
350VFALTVINTAGE FUEL ALTERED COUPE
351VFCCVINTAGE FUEL COMPETITION COUPE
352VGALTVINTAGE GAS ALTERED COUPE
353VGCVINTAGE GAS COUPE
354VGCCVINTAGE GAS COMPETITION COUPE
355VOTVINTAGE OVAL TRACK
356TTURBINE VEHICLE
357DSDIESEL STREAMLINER
358HH2HIGHWAY HAULER II
359HH3HIGHWAY HAULER III
360BFMSBLOWN FUEL MODIFIED SPORTS
361MGMSBLOWN GAS MODIFIED SPORTS
362FMSFUEL MODIFIED SPORTS
363GMSGAS MODIFIED SPORTS
364CBFALTCLASSIC BLOWN FUEL ALTERED COUPE & SEDAN
365CBGALTCLASSIC BLOWN GAS ALTERED COUPE & SEDAN
366CBGCCLASSIC BLOWN GAS COUPE & SEDAN
367CFALTCLASSIC FUEL ALTERED COUPE & SEDAN
368CGALTCLASSIC GAS ALTERED COUPE & SEDAN
369CGCCLASSIC GAS COUPE & SEDAN
370CPROCLASSIC PRODUCTION COUPE & SEDAN
371CPSCLASSIC PRODUCTION SUPERCHARGED COUPE & SEDAN
372SSTEAM
373BFRMRBLOWN FUEL REAR ENGINE MODIFIED ROADSTER
374FRMRFUEL REAR ENGINE MODIFIED ROADSTER
375BGRMRBLOWN GAS REAR ENGINE MODIFIED ROADSTER
376GRMRGAS REAR ENGINE MODIFIED ROADSTER
599TOTIME ONLY
I came across this might have some useful info.
Performance Trends Blog
Just another WordPress weblog
Things to Consider Before Top Speed Racing at Bonneville Salt Flats​
Posted byDennis Gertgen August 19, 2009
Top speed racing is very much like drag racing, but just on a very long track. In drag racing, it is power to weight ratio which typically determines your performance. However, when the track is very long, and your vehicle spends much more time at high speed, it is power to drag ratio which is more important. By drag, I mean primarily aerodynamic drag or wind resistance. In addition to aerodynamic drag, there is rolling resistance from tires, driveline losses, but the higher the speed, the larger the aerodynamic component of overall drag.
To improve the power to drag ratio, you want to increase the power and reduce the drag, which makes sense. To go faster, you need more power and you want to make the car more aerodynamic. However, what you may not know, is that to go twice as fast, you need eight (8) times the power. If your 200 HP car can top out at 120 MPH, you would need 1600 HP to top out at 240 MPH. (You would also need some really good tires to hold together, and good aero downforce to stay on the road).
Most all racers have some idea on how to improve the engine’s power. Engine power can be fairly reliably simulated with our Engine Analyzer computer programs, and these can all be tested with an engine dynamometer and our Dyno Datamite software.
The biggest contributors to aerodynamic drag are the vehicle’s frontal area (silhouette of vehicle when viewed from the front) and it’s drag coefficient (a rating of how easily the vehicle slices through the air for it’s frontal area). Drag coefficients vary from a high value of about .8 for an upright rider on a vintage motorcycle, to .6 for an older pickup truck, to .4 for a modern aerodynamic sedan, to .35 for a modern sports car, to an incredibly low .15 of “pencil shaped” land speed record cars like the Blue Flame.
To optimize the aerodynamics of your particular vehicle, you should read everything you can get your hands on. The basic shape has a large effect, but subtle things like windshield moldings, vehicle rake (lowering the front end), underbody protrusions all add up to huge improvements. Typically you just make these mods you have read about and hope for the best, because it is very difficult to measure if your aerodynamic mods have made any really improvement.
The best way to actually measure the effect of aerodynamic mods is to rent a wind tunnel, at around $50,000 per day. For the rest of us, we can preform coastdown tests. This is where you get your car up to a top speed, throw it in neutral and let it coast to a lower speed. For this to be accurate, you should use the same stretch of very flat road, and do the test in both directions to minimize the effects of wind and slight grade of the road. If the coastdown times, from say 100 to 60 MPH has increased 3%, it means you have made a 3% improvement (reduction) in drag coefficient.
The best way to do coastdown tests it to do several and average the results. It is also best to use some type of data logger so you get lots of accurate data and the driver can concentrate on driving. From doing coastdown tests myself, I can say that this requires lots of tests and patience to get good results. Also, the higher the speed (not on public roads), the better the results. There is also software which can separate how much of the coastdown drag is from the tire rolling resistance and how much is from aerodynamic effects, and come up with actual numbers, like your drag coefficient is .322.
OK, so we’ve talked about the power to drag ratio contributors. But there are other, secondary effects which also have an effect. These effect how efficiently you take advantage of the power to drag ratio you have to work with. For example, top speed tracks vary in length, from Maxton’s Monster Mile at just 1 mile, to El Mirage’s 1.33 miles, to Bonneville’s legendary 5 miles. To get the optimum top speed, you want to get to top speed quickly, to optimize acceleration at all times. This gets back to the drag race idea. You don’t have to worry about 60 ft times or pulling wheelies, but you do want to optimize your shift points. A quick El Mirage computer simulation showed a .6 MPH improvement on a 140 MPH car by shifting quickly at optimum RPMs, vs “lazy” shifting at RPMs about 1500 RPM off optimum.
Total gear ratio is critical. You want to put the engine at it’s peak HP RPM when the vehicle reaches top speed. The peakier the power curve, the more critical this is.
Another aerodynamic effect is lift. The lift coefficient determines how much your vehicle acts like an airplane wing. If you have a high lift coefficient, you loose traction at the tires and loose steering control. Too much negative lift coefficient, and your tires have to do more work and rolling resistance increases. This is another item which will require you reading up what others have done. Lift coefficient is very difficult to measure, but you should be aware of its effects as it has a huge effect on safety.
Another detail is a hood scoop efficiency. An effective hood scoop at high speed produces significant boost pressure for the engine to improve power. For example, a perfect hood scoop at 200 MPH will produce .75 psi boost, which equates to approximately a 5% power improvement. However, if you have to increase the drag 10% with a big, protruding bump on the hood, it’s probably an overall loss to top speed.
To truly understand all the things which affect “real world” top speed performance, you need a vehicle simulation programs like Drag Race Analyzer or Drag Race Analyzer Pro which lets you modify things like we’ve talked about, which include:
  • Actual engine power curve through entire RPM range
  • Drag coefficient and frontal area (and possibly lift coefficient).
  • Transmission and final drive ratio
  • Hood scoop efficiency
  • Tire type (to estimate rolling resistance)
  • Track length
  • Shift RPMs and shift type (fast, slow, power shift, etc).
We carry many other programs that can be used for Land Speed Record applications including: Drag Racing DataMite, Rotating Inertia Calculator and our Engine Analyzer programs.
You also want to read up on what ever you can find on top speed racing.
Is it BVGCC ?
Cubic InchesLiters
AA501+8.210+
I46–61.99.754–1.015
J31–45.99.508–.753
Yes these are the classes. I would be in B as is. Would rather run C.
And no. You picked Bown Vintage Gas Comp Coupe.
I plan to run B/BGALT or B engine size, blown gas altered. Would like to go down to C/BGALT
Looks like to be in C you'd be going small block or destroked big block or 361, 340/360 probably be good choices, If going B I'd drop a 440 crank in a 383 making 432-438 could even go 0.070" to 440 bore.
Ok well ****. Alex's 235 record bumped the 224 in C/CBGALT. SO, now with only at 8mph difference, there is no need to go thru the trouble. 2024 records are not yet in the book. Duh
I did see a great video of Keith Turk discussing his Bonneville years. They got the aero good enough on that Camaro, that 800hp will go 260mph. Super jealous.
They failed a lot and learned a lot. That Camaro has been around the block a time or 10. At this point it’s a very well sorted car.
Agreed. From a $800 beater to something that full on works
Coming late to this party. How advantageous would an inline motor be, since it may allow a significant reduction in vehicle width? A turbo in front of the motor?
This is the concept people use when building lakesters and streamliners. My friend has a highly modified Buick Straight 8 in his Lakester. In each class, certain modifications are allowed.
Those Buick straight 8’s were great engines.
This one is destroked for displacement class rules and RPM. Also has 13:1, ported head, custom cam and intake with twin Holley 2 barrels. It is getting more work done this winter, which may include EFI.
I say a carbed 6.1 twin turbo gen3 hemi. If you don't want to run the hemi. I just found a guy on Facebook market place selling a complete I think a R5P7 engine. I don't know the guy and know very little about this engine. So with that and your are interested in it I can send him your contact info. If you would like. Here is some pics of it I took off facebook.
