What's Your Stand On Stance?!
MrJLR
Built, not bought
Menifee, California
Some like them slammed...
Some like it stock...
Me, I like my '70's "stink bug" stance...
To each their own. ...it's all good as long as it's Mopar!
Post 'em up...here's mine!
Jeff
A couple of inches of rake, car lowered as much as you can and still street drive it, rear tires as tall and wide as possible WITHOUT sticking out of quarters.
@Mopar-Man
what is it exactly that you disagree with?
Jeff
First of all, you have a beautiful car. But, if you are going to run the same size tires then the car will look better leveled. But the way you have it sitting, it needs a taller rear tire. The distance from the top of the tire to the wheel opening front and rear should be almost the same. Also, it looks better to have the front/rear track the same OR the rear slightly wider.
This is just my opinion and you asked so there ya go.
View attachment 1715042381 View attachment 1715042382 View attachment 1715042383
Jeff
I know many members aren't going to like it but I prefer the "PISSED OFF" stink bug look of the late 60s early 70s:
I've recently added a few 60s stickers:
And I don't need a super low profile jack to get the car high enough to get a regular jack under the frame....I just lay on the ground and slide under the car to do any work!!
Treblig
For some reason I have always liked Mopars a bit over stock height on both ends with a slight rake.
To each his own...like I said.
Jeff
View attachment 1715042403 View attachment 1715042404 View attachment 1715042405
View attachment 1715042406 View attachment 1715042407
Treblig
Badass!
Jeff
honestly, I don't have a preference. there's some cars that look good slammed, others look good shackled up with huge rear tires, other's stock. I guess I like them all
I prefer super huge tires on tiny 14" wheels that are too narrow for the tires I run on them. Jack the front up all the way and use shackles out back to get er' up even higher. 4x4 stance.
Nah..kidding. There are so many wheel/tire combos it's too had to say what looks right with each one. I'm not a huge fan of seeing a lot of space/air above the tires. I like a slight rake.
