What's Your Stand On Stance?!
Just level.
Anything "slammed" all the way down OR donked out I fuggin hate. Everything in between, pretty much love it. Although nothing beets that old school raked look from big drag tires out back and pizza cutters up front! JMO.
Depends 100% on the car. Some body styles look good IMO low, some look better tall. It really just depends. The current car I'm working with, a '67 FB Barracuda, looks good with Super Stocks & 275/60's which put it up in the rear. I'm running 155R14 tires up front on 14x5 ET V's & the torsions cranked up to add header clearance but will probably lower it about 1" up front for more rake.
Depends 100% on the car. Some body styles look good IMO low, some look better tall. It really just depends. The current car I'm working with, a '67 FB Barracuda, looks good with Super Stocks & 265/60's which put it up in the rear. I'm running the torsions cranked up to add header clearance but will probably lower it about 1" up front for more rake.
What size are the rear tires? Never mind, just saw. Duh....
I like the old school rake and the big meats out back. Considered the pizza cutter look up front but settled on 205's.
I believe the right stance is the one thing that can make a good car great.
Slight rake, wide tall tires... Here's mine.
Does anyone here know if 275/r15's on a 15 x 8" rim will fit a 67 barracuda without cutting the rear are fenders?
Does anyone here know if 275/r15's on a 15 x 8" rim will fit a 67 barracuda without cutting the fenders?
That's what I'm running, 275/60R15 on 15x8". They don't fit under the car but they don't run the front of the fenderwell, they are about 1" from it.
Need to take some current pictures but I love the slight rake with wider tires in the back. But I agree that each car has it's own look and variety is good.
Mine are on the back, I'm meaning the front of the rear fenderwell where A-body's are typically close to the tires when running large rear tires.
So you have air shocks or springs that keep your fenders from hitting the tires?
