Snake
Mopar Nut
When I took apart my front drum brakes on the dart i was baffeled when i tryed to undo the wheel cylinders.The 2 bolts are hid kind of behind the spindell.I had to remove the backing plate to get to them easy.Could someone have installed to big of a bolt.I just bolted the spindell lower ball joint and backing plate all together minus the wheel cylinder thoes bolts for the cylinder seam to big.I had to undo everything wheel cylinder first then everything after.What gives
