wheel clyliders 69 dart
Snake
Mopar Nut
Belleville Canada
When I took apart my front drum brakes on the dart i was baffeled when i tryed to undo the wheel cylinders.The 2 bolts are hid kind of behind the spindell.I had to remove the backing plate to get to them easy.Could someone have installed to big of a bolt.I just bolted the spindell lower ball joint and backing plate all together minus the wheel cylinder thoes bolts for the cylinder seam to big.I had to undo everything wheel cylinder first then everything after.What gives
Ran into the same problem with my car Snake, and I am positive my bolts are original to the car. I ended up screwing the bolts all the way in by hand (clean the threads with a tap first) then used an open end wrench to snug them down.
What holds the wheel cylinder to the backing plate is the fit of the cylinder into the opening of the backing plate. If the bolts alone were used to retain the cylinder, they would sheer instantly as soon as the brakes were applied. Having said that, the bolts only job is to hold the cylinder snug to the backing plate. They don't have to be very tight.
George
