For the sake of being 100% sure i rmemove the pass side motor mount and it is all good.
The tranny is a 833 OD , flywheel is nos for 360 clutch is centerforce diafram type. I tried backing off rear brakes no real diff. It's one of those things you'd have to feel to truely understand. Just don't know .
My 2014 Grand caravan has a reverse that is seriously underengineered. If you put it in reverse and try to back up a hill, like a nose down parking spot, it makes all kinds of weird jerky movements. Quite a few pages on the support site.
Getting back to rear wheel drive solid rear axle classics...Generally you want the trans and rear pinion on a net zero setting on acceleration. Let it be 0,0 or -2,+2. On general driving, you want it down a few degrees. These are static measurements at rest. Remember your measuring in relation to your trans angle.
Suspension Recommended Angle
Using Full Wolfe Race Craft Suspension - all solid mounting points. -1 to -1.5
Half Solid & Half Poly Mounting points -1.5- to -2.5
All Poly mounting points -2.5 to -3.5
All Rubber mounting points -3 to -4.5
The more you get away from having all solid mounting points the more the rearend is going to try and rotate upward during launch. Therefore the more angle you must start with to prevent the angle from becoming positive (+). The idea is that when the rearend rotates you want the angle between the driveshaft and the pinion would be 0.
Here is a question and food for thought. I read an artical strictly for mopar pinion angle and it states mopar factory at the tranny is set at 0 degree and rear should be 3 to 4 degree down. I get that and understand. I have tranny down at 2.4 degrees and no way can i tilt the tranny up any just no tunnel room. So here is my thought. I had it with 2 degree shims on the front side and if i slipped the clutch slowly it some what worked. How about i use a set of 4 degree shims. I had 1.5 degree down using the 2 so i figure the 4 should give me about 3.5 down . What do you think????Exactly right. This is why the MP suspension book tells us the pinion should be 5-7 degrees nose down in relation to the transmission output shaft. So that when the vehicle accelerates, the pinion pulls itself up and becomes aligned parallel with the transmission output shaft. Of course, for "most" street cars, technically 5-7 can be a little much, but it will still work. No matter how much you preach it, you simply cannot get people to understand and do it.
Motor mounts are correct, i actually had to use 2 1/8 inch shims under the k frame to get the oil pan away from the steering cross link so it would not rub the ooil pan when turning. I tried removing the to see what i might gain, only 1 half a degree. Car came with 273----a terd so i put a 360 in. Maybe a different oil pan and rework the motor mounts to get to 0.That’s what we have been telling u all along. U just weren’t listening to us. I can’t see why u can’t get ur tranny to zero unless ur motor is too high. Do u have the right motor mounts and brackets. Something is amiss. Kim
Doesn't sound like it.Do u have the v8 drop link in it? Something can’t be right. Kim
Honestly i don't know, it drops down about 4.5 inch. I would think it does since it came with a v8.Do u have the v8 drop link in it? Something can’t be right. Kim
I understand what people have been saying, it's just that i have read so many articles on this and got mixed opinions. Now that i understand mopar is a different animal i can try what others have been saying, down with the rear angle.I believe the book was giving an example with the transmission at 0* to make it simple to understand. They are telling you that "wherever" the transmission "is" the pinion should be 3-4* down "from that". .......just like everyone has told you all along.
Ok so here is my latest and greatest. I reversed the shims and no have a 2.7 degree down. Test drove and 100% better but still backing up a slight up grade i get some shudder not quite the thud i had before. So now i have a total of 5.1 between tranny down and rear down. I have a set of 2 degree shims, too much --' more or less to add.I believe the book was giving an example with the transmission at 0* to make it simple to understand. They are telling you that "wherever" the transmission "is" the pinion should be 3-4* down "from that". .......just like everyone has told you all along.
Well i added the 2 degrees more this morning so now i have a down rear of 5.1. . I don't see much if any diff from last time. If i slip clutch i can make it work. Don't know what else to do. All bushings seem good, motor mounts seem good. If any of yall live in york pa and want to take a swing at this thing, literally a 10 pound sleg swing i can make it happen.I would go "a little farther down" on the pinion angle. The angle you are looking for actually is the working angle, which is the difference between the two. Mopar never really looked at it that way. They always gave the two angles separately.
Might end up being a clutch issue. I've never seen a clutch chatter "only" in reverse, but there's a first time for everything. Have you checked the transmission mount?
Here is something i have been thinking about. When i originally put the conversion in i used a ram clutch with the 3 fingers and trying to use a hydraulic setup. I found out you can't use hydraulic throw out and 3 finger clutch. So i kept the disc and bought the centerforce diafram pressure plate. Could the mismatch be the issue. I think the centerforce is actually stronger than i need, it grabs pretty hard right off the bottom.I can't remember the ratio but you can get clutch chatter in reverse and not in low gear. It's the way the chassis gets loaded while backing up, the extra ratio of reverse and the pulsing of the firing cylinders on the crank.
You sometimes see this when the disc doesn't have a marcel in it. The thin, wavy spring between the clutch materiel and the disc itself. Or an unsprung disc can do that.
The real cause of all those issues listed above is from too much plate load without a marcel or an unsprung hub or both. I run an unsprung cintered iron disc and don't have the issue of clutch chatter in either direction, but about the highest plate load I have is about 1000 pounds. If I put 2400 pounds on it, it would rattle my teeth out, and probably shake the dash right off the car.
I found the same thing with a CFII disc.it grabs pretty hard right off the bottom
