Make sure the hub clears the wheel; I'm going to have to radius the nose of the hub a little. For the garage I am using a 7mm spacer to allow the wheel to clear so I can roll the car.
I forgot to mention that I had the wheel machined about 3/16" in hub depth.Make sure the hub clears the wheel; I'm going to have to radius the nose of the hub a little. For the garage I am using a 7mm spacer to allow the wheel to clear so I can roll the car.
Ya gotta have a beer fridge. When we got a new one for the house, i took the old one out to the shop. Comes in handy to have too when you need to stock extra goodies for an upcoming party.New beer fridge! And all my glass is cleaned, tinted and wrspped up on top of my messy box. Just need to start polishing SS. But this post is mainly about the new beer fridge, which is awesome!
Dark metallic green.Black interior ? Or dark green?
Yep. Fit was ok. I had to do some 'tweeking'. And ran a small foam strip between spoiler and valance. Here it is installed.Is that a Randy’s spoiler on the front
Your gonna have a problem here you either have to grind away part of the gage bucket shown in red to get the volt gage lower pendulum to swing so the needle will move, or cut that part off the gage do it clears. I ground my gage bucket instead. Not sure how much removing the pendulum interferes with the gages calibration.
I used led 5630 dimmable flexible peel and stick light strip for my gage backlighting. Its inexpensive and eliminates bright and dark spots. I will post pix if your interested. It works very well. I can sell you a 4 foot strip if interested. I have it in your fav colour. Green.
I'm interested in the lighting you are talking about if you could post a photoI used led 5630 dimmable flexible peel and stick light strip for my gage backlighting. Its inexpensive and eliminates bright and dark spots. I will post pix if your interested. It works very well. I can sell you a 4 foot strip if interested. I have it in your fav colour. Green.
Thanks. That does light things up!That brightness was with a 9v battery. First pic shows how i soldered it to a bulb socket and plugged it it.
