So I came out Friday morning to take it for a birthday drive and lo and behold I had a crank, no start situation. Now the confusing thing is when I drove it on Thursday. All I did was pull it into the garage and shut it off. I didn't open the hood, I didn't mess around with anything, I just got out and went inside.
So Friday began my troubleshooting. I spent an hour or two messing around. As always I started with the basics. Good battery voltage at 13.6. I had fuel pressure, both on my gauge and signal from my pressure sensor. Checked spark at number one cylinder and nothing. Checked spark at the coil and nothing. Checked 12 volts at coil while cranking and nothing. Checked 12 volts at bulk head while KOEO and cranking, had voltage there. Moved on down the line, checked KOEO and cranking voltage at ECU and hyperspark, had it there. Checked mag purple and mag green from the Hall Effect and had crank signal to ecu. Also verified tack output and rpm signal on display while cranking.
So this told me the computer was getting a crank signal but, for whatever reason, the computer was either not outputting a signal or the hyperspark box was bad. I then deloomed some harness and double checked pinouts and terminations. All seemed well. I then went KOEO and grounded the hyperspark input trigger and got spark at the coil. This told me that the hyperspark box was functioning.
I then turned my attention to the ECU. Grabbed a LED test light, hooked it up to battery positive and the ECU ground pulse trigger and nothing. I then set my DVOM to continuity min/max, one end to battery negative and the other to the trigger and no pulse.
So at this point, I've determined the ECU is not functioning properly and probably needs to go into Holley. I tried calling the Holley tech line but Friday was a holiday. So I packed it up for the day. So I tried calling Saturday morning and they are closed Saturday and Sunday. Sunday rolled around and I started digging around on Holley's website. Started going through their documentation on software updates and, thank God, one of the newest firmware updates fixes the ground pulse trigger. So I uploaded the new firmware version and the car fired right up. So I took my kids for a ride. LOL.
