Hello all,
Over the next few years my engine builder and I will be building a race only engine looking to run low 10's in a 73 Duster. The engine will be using W2 or Indy 360-2 heads and a 3.58" crank with 340 mains. I have various intakes including a tunnel ram to try and plan on a solid roller cam.
My engine builder has kindly offered to swap me a 48 degree block for my 59 degree R3 block if I wish. I understand this will require a specific cam, headers, timing cover, and also the modification of the intake manifolds. Going this route requires a bunch of one off stuff I will need to buy and added expense. Benefits of course are lighter pistons and improved valvetrain geometry.
My question is this, at what point is the 48 degree block a real advantage over 59? What RPM can one spin reliably on a 59 degree 1/4 mile drag engine with good parts. Is it required for what I am tryimg to do? All of my stuff and associated parts are 59 degree at this point providing ease of parts swapping and interchange. I am not opposed to the 48 degree change, I would just like to make a very well informed decision. Any information you folks can provide me about this switch in an A body will be most appreciated. ie. Exhaust fitment, etc.
Thanks in advance for input.
