where to outlet my exhaust
Mopar Exhaust Systems
  1. YoungDuster
    YoungDuster Well-Known Member
    83
    2
    Oct 19, 2014
    Canada
    Local Time:
    1:50 AM
    Getting header put on my 72 duster so figure ill get rid of the stock exhaust itll be 2.5 in pipes off a 3 in header H pipes with to flowmaster super 44 mufflers where should i put the outlet turned out in front the the rear wheels ?behind the rear wheels? straight out the back? And what exhaust tips should i use? Open to all suggestions Picture would be great
  2. crj1968
    crj1968 Well-Known Member
    455
    19
    May 28, 2014
    Idaho
    Local Time:
    11:50 PM
    I like the factory look
    [​IMG]
  3. furyus2
    furyus2 Well-Known Member
    2,178
    673
    Oct 30, 2010
    weeki wachee fl
    Local Time:
    1:50 AM
    Out the back. In front of the wheel will make you deaf, and behind it will rust your quarters.
  4. ssba
    ssba Well-Known Member
    2,293
    350
    Dec 29, 2009
    rensselaer in
    Local Time:
    12:50 AM
    I've had them turn down in front of the axle to save on the cost in the past.
    It was far enough back that I didn't hear it resonate at any particular rpm.
    If you have ever had a side exhaust do that it can be hard to tolerate if it
    happens at your normal driving speed. Way worse than open headers
    in my opinion.
  5. YoungDuster
    83
    2
    Oct 19, 2014
    Canada
    Local Time:
    1:50 AM
    Beautiful car, so looks like out the back it is i like those square tips they look really nice
  6. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
    19,239
    7124
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    12:50 AM
    -Nice tips cr. Yeah I like the factory tips too.
    -If you send the pipes straight out the back, they tend to attract cops. 2.5s are loud, but not as loud as 3 inchers. I put turn-downs on my 3s with dynomaxers. Its tolerable until I stand on it.And Im the only guy around here with 3s, So everybody knows its me. Very distinctive sound.
  7. abodyjoe
    abodyjoe Well-Known Member
    20,904
    6191
    May 22, 2004
    Berlin,N.J. 08009
    Local Time:
    1:50 AM
    out to the bumper. looks the best to me.. and you'll hear a lot less of it inside then the other places you mentioned.
  8. pishta
    pishta I know I'm right....
    18,333
    7825
    Oct 13, 2004
    Tustin, CA
    Local Time:
    10:50 PM
    To the bumper with turns downs tucked up tight. Round pipes out the back looks cheap and turn downs under the axle is loud inside. Was considering boom tubes out the psssenger side like a ford lightning truck?
  9. Cuprum-74
    Cuprum-74 Moparus Fanaticus
    518
    89
    Dec 6, 2012
    Utah
    Local Time:
    11:50 PM
    Yep I got dual 3 inch exhausts as well with Summit Street & Strip muffler.
    I have them routed out back with cheapo turndowns.
    I might have them replaced with dual 2.5's with X-pipe, chrome turndowns and either magnaflows or dynomax's.
  10. YoungDuster
    83
    2
    Oct 19, 2014
    Canada
    Local Time:
    1:50 AM
    i dunno it has turn downs on it right now but i really like the square tips about how much louder are you talking with super 44s it seems deeper like a heavy rumble, less of a roaring sound
  11. Hemaniac
    Hemaniac Active Member
    37
    0
    Nov 11, 2014
    Glasgow Scotland
    Local Time:
    5:50 AM
    go out the rear with tips always classic looking
