Dusterdude72
IN MOPAR MUSCLE MAGAZINE
Ok guys......I built a 600 eddy 4 barrel electric choke carb for my duster awhile back ...... I ended up picking up a truck that had a bad carb on it and I robbed the carb I built for the duster and stuffed on the truck and then sold the truck.
so now I have no carb for the duster and I am thinking of just buying a new one.
my question is....which one? I am thinking of 1 of 2 carbs ......either an eddy 600 with electric choke..... or a 670 holley street avenger with electric choke.
I am leaning towards the 670 but I am thinking I might have to get a couple other things to make it work.....reason being is that with the dual feed line in place I am pretty certain that the fuel line will hit my intake (so I will have to get a carb spacer for it) and THEN I am not sure what kind of hood clearance I will have so I may have to get a drop filter base. But at the same time...I had a 670 street avenger a few years back and I loved it.
But I have also had good luck with the eddy carbs
here is my setup..... 67 318 with factory 67 318 heads ( I believe I ran the numbers and it came out to 2.02/1.60 for valves), block has been punched .030 over, dished poly pistons, block is decked and heads milled,purple shaft,eddy performer dual plane intake,long tube headers,2.5 dual exhaust,2500 stall converter,B&M pro ratchet shifter,28" tall tire with a 4.56 8 3/4 (489) sure grip posi.....I think that basically sums up the performance aspects if it gives you guys any better of an idea.
I am not looking for an all out drag car, just a driver car I can take to shows now and then that has a bit of pep in its step.
