If that’s the case, then (according to Edelbrock in comparing the air gap to the LD340) there’s probably not enough gain for the expense (even used) of an air gap.
That’s the whole thing right there. There is no chase for an ET slip or maximum power output that can justify spending the money on a RPM AG over what he already has.If that’s the case, then (according to Edelbrock in comparing the air gap to the PD340) there’s probably not enough gain for the expense (even used) of an air gap.
see post #34The stealth (which is just a carryover of an older numbered intake) is a look alike and has the same port dimensions as an LD4B.
A member here (if not a few members) a while back called up Edelbrock and asked the important question straight out which was is it worth dumping your older LD-340 for the then New (ish) RPM AG in which the reply was No. Right out of the companies mouth. While the tech’s did note it would be a better intake than the older LD-340, the cost wasn’t worth the swap.
I myself hoping the pendulum was going to swing a bit more in my favor for testing such a thing. I have wanted to dyno test a few engines I have for the fun of it with a focus on intake manifolds. I have two engines about ready to be hooked up to the lie detector test with a few intakes to run for fun. But this is expensive to do and I’m not going to get all the testing done overnight!
What dual plane intakes do I have?
Weiand’s Action Plus & Stealth, RPM AG, Chink knock off of the AG and a D-64 dual quad. Also a 6-pack.
Why? Why the heck not?! I’m entertaining myself with this idea just for curiosity sake.
There are two models. One is for the early smaller and odd angle intake bolts for the 273, the other is for the normal intake and angled bolts. D-66.Well dammit, now I want a D64 Dual Quad. Never heard of that one.
well i did look after i read all these and yes they are very badLook at the ports carefully. Like, put your glasses on. They're hideous.
this sounds very entertaining and id love to hear the resultsThat’s the whole thing right there. There is no chase for an ET slip or maximum power output that can justify spending the money on a RPM AG over what he already has.
Me too! LOL!this sounds very entertaining and id love to hear the results
YesAll this is gong on your YouTube channel I hope!!
i pulled a 69 340 with x heads out of a van with a 2bbl on top of it and an engle cam.With the price of gas you could use the cast iron 2 barrel intake off a 71 318...( I'm wondering when they will become valuable I have one I'm ready to turn in at the scrap yard ) I think you'll see it one day someone saying they are looking to run a BBD on a 340... if Unclke Tony sells it someone will buy ...LOL!
Stating the obvious. You tune for the worst cylinder and I'll take the manifold that does the best job at minimising that variation.Most every! intake has fuel distribution problems.
Hughes has a good deal on those right now.I used to run an edelbrock airgap and thought it was the latest and greatest. Switched to a Victor 340 and did everything the airgap did and then some!!
I think I got the best deal on my Victor! A member here was selling his victor intake since he didn't feel confident/comfortable using in a street car. So I proposed we trade my airgap for his Victor. He agreed. Only issue was he is in Missouri and I'm in Texas! Determined we shipped each other intakes as an even trade!!Hughes has a good deal on those right now.
This depends on a few things about the engine. LOLI used to run an edelbrock airgap and thought it was the latest and greatest. Switched to a Victor 340 and did everything the airgap did and then some!!
I have a Holley Street Dominator on my 340 in my Van and it is awesome. It's the best of both worlds for me.If you do swap
It's one of the most overlooked and misunderstood intakes ever and all people can say when you recommend them is "but it's a single plane, it's gonna suck down low". So I just give up. lol I have one on the 400 in my Ford truck and it'll pull the boogers outta your nose on the bottom end.I have a Holley Street Dominator on my 340 in my Van and it is awesome. It's the best of both worlds for me.
