Chryslerkid
Did you ever rebuild your 7.25? What kind of built 318 do you have in the car? Stock? Just trying to get a feel of if your HP and tq output is the same as mine will end up being....
I think I mentioned this, but it's worth repeating. The stock compression height on a 318 is 1.720. You can get aftermarket stock replacement pistons with a taller compression height. 1.741 is a popular replacement. Might not seem like much, but every bit helps. It helps more than you might guess. Those pistons can be had for under a hundred bucks if you shop around.
If you could get away with a rering job would you need to rebalance with these pistons since there stock replacements?
After reading this, I was thinking how much fun it will be when you build this motor and people ask "What's in it?" and you say "318." And they say "oh" as if disappointed. Then they hear and see it run. There will be a different "oh" then.
Will someone please tell me the HP and TQ of a stock LA V8 318 engine from 1987 out of a dodge van with a 2bll carburetor? No aftermarket parts. Thanks,
Does anyone know If I can go online and input my own specs from my build in order to figure out my HP and TQ without paying an arm and a leg to someone who owns a dyno? Not just stock ratings....
Stock compression & cam i assume i'll run in my program tonight, a guess though 200hp.
