Alright. I am seriously considering tearing into my '87 318 block and rebuilding the entire engine in my garage. IF... I do this, I'm doing it right! So I am buying KB pistons, J heads, radical cam.... Will I need a different crankshaft? If so what are the cranks y'all use? I'm going to make some power out of this 318 while it's out of my car. This is the time to do it. What are your ideas guys. I am ready to order all the parts and send the block to the machine shop.
If your gonna now rebuild your engine and use KB167 and zero deck your block and use around 0.025" gasket and your 72ish cc J heads will give you 9:1 CR add a high lift 268 cam and a Eddy Airgap Rpm intake and 650 Holley you'll have 350hp.
