71DodgeDemon340
Are just the rubber wiper blades available? I know pushing the button removes the blade but it appears the blade will slide out of the plastic spine
Those are Anco's (I believe) with the little red push button to get them apart. They should be 15" but measure to make sure. It's best to take the blade assembly off the arm and bring it to the parts store with you. Try NAPA first. They will probably have what you need.Are just the rubber wiper blades available? I know pushing the button removes the blade but it appears the blade will slide out of the plastic spine
