7dart0
I'm fighting a overcharge issue now. Everything was fine then the alternator went full field at idle. Started charging to 17v. Just another bump in the road.
You may have lost the voltage regulator, especially if it was an original. Melting down the ford solenoid may not have done it any favors.
My original VR checked out not too long after I went to my new 100 amp alternator. I replaced it with new on and haven’t had any issues since.
I tried 3 different voltage regulators all with the same outcome, way overcharging. I have almost 0 voltage drop from ground wire at the block to the Voltage regulator case. I have about a .2 volt drop from output sensor wire from the ignition bulkhead wire to positive side of the battery. I'm pretty sure the alternator let go. Its a reman unit from autozone about 2 years old. unless my one year old AGM battery is bad but it cranks over fine.
When referencing the diagram at the top of this thread, if using a one wire alternator in a drag car that has no factory wiring, where does the alternator output wire come into play? Also, I'm using an MSD7AL-2 ignition, would the +12V 'ignition exciter' wire, from the ignition toggle switch on my switch panel, take the place of the 'field' wire going to the CDR in order to kill the ignition when the kill switch is thrown?A ford solenoid is not designed to stay energized for long periods of time.
He has a photo and diagram here:When referencing the diagram at the top of this thread, if using a one wire alternator in a drag car that has no factory wiring, where does the alternator output wire come into play? Also, I'm using an MSD7AL-2 ignition, would the +12V 'ignition exciter' wire, from the ignition toggle switch on my switch panel, take the place of the 'field' wire going to the CDR in order to kill the ignition when the kill switch is thrown?
Concerning the alternator output wire, I'm running a one wire alternator in my drag car. There is no factory wiring at all, meaning there is no alternator 'field wire' as shown in the diagrams. What I had done previously was to run the alternator output, via a number 6 wire, directly to the battery side of the kill switch. The problem with this setup is that even with the kill switch pulled, this wire is still hot. My question is given that I have no factory wiring, where on this diagram would my alternator output wire connector in order for the kill switch to function properly, and by properly meaning that ALL power is cut off when the kill switch is pulled.He has a photo and diagram here:
questions about battery disconnect wiring
As far as alternator output wire, not sure what you're asking, but basically it supplies everything once the engine is running.,
If the MSD 7 is like the 6, it sounds like you're talking about the wire for the internal relay. That wire is your on/off switch. Connect it to power and a small current turns on a continuous duty relay inside the MSD.
The thing is that unless you actually disconnect the battery(s) at the terminal no matter how you wire it there is always going to be some wire somewhere that is hot. The idea behind the rule in NHRA is that all power to the ignition and fuel pumps be cut off via one central switch on the back of the car. Wiring it the way you did (and as I did) cuts all power the everything except the one wire from the alternator to the battery.Concerning the alternator output wire, I'm running a one wire alternator in my drag car. There is no factory wiring at all, meaning there is no alternator 'field wire' as shown in the diagrams. What I had done previously was to run the alternator output, via a number 6 wire, directly to the battery side of the kill switch. The problem with this setup is that even with the kill switch pulled, this wire is still hot. My question is given that I have no factory wiring, where on this diagram would my alternator output wire connector in order for the kill switch to function properly, and by properly meaning that ALL power is cut off when the kill switch is pulled.
You must not have looked at his diagram.Concerning the alternator output wire, I'm running a one wire alternator in my drag car. There is no factory wiring at all, meaning there is no alternator 'field wire' as shown in the diagrams. What I had done previously was to run the alternator output, via a number 6 wire, directly to the battery side of the kill switch. The problem with this setup is that even with the kill switch pulled, this wire is still hot. My question is given that I have no factory wiring, where on this diagram would my alternator output wire connector in order for the kill switch to function properly, and by properly meaning that ALL power is cut off when the kill switch is pulled.
