skep419
5.9 Magnum 4 speed afficionado
Not worth the trouble. Was in the same boat a while back. Swapped cam, intake, heads, carb. Wish I would have just wated and built the bottom end while I had it apart. If you do anything I would buy parts that will work with the combo you can't afford at the moment (carb, intake, converter). $Save$ for the total package.
