Hello
just purchased a 70 Duster with a 318. when I went to look at it it wouldn't fire. Crank crank crank. Key in run position: voltage at both sides of ballast. tried jump solenoid no go
ran 12v to ballast direct from battery- same no work
looked at ECU wiring. Owner swears the car started and was fine before. everything looked ok. Yellow black to neg coil etc...
I remember green wire not being used on ECU's I've wired in, but with single ballast. This car has dual ballast and green wire is going to the ballast. So pulled the dual ballast plug and just plugged in one side to the resistor (brown?) letting the green wire just be not connected.
Car fired right up. let it warm up etc...
Put in gear, dies...every time. Like it lost it's ignition, by just putting it in gear
Put the ballast wire back on how it was, with the green wire connected to ballast again (when there was no spark before) and now car starts and drives. ??? I've gotta drive the thing home tonight and I'm not feeling totally confident
Anything jump out as obvious to anyone? bringing a spare ballast and ECU with me...
