You must make the length of the plug wire correspond to the length of the intake runner....longer intake runner needs shorter wire and shorter intake runner must use longer wire....and then you must take in account the actual tube length of your header and take the square root of that number...
When your girlfriend is in your hot rod and you are loosing by 4 car lengths, she will not be impressed. Yes, sir! correct plug wire length and 4 drilled holes in the distributor cap to let the static out, and them 4 car lengths are made up, your girlfriend will not be embarrassed, and your face will be saved!So I guess the final question is, do chicks dig 'em? Because I ain't doing it if they don't.
yes, yes. this is the exact math I used to drop almost a full second. I also, which has not been mentioned in this thread, picked up 2 mpg using this exact math.
Are you aware that you just brought back an old dead thread from YEARS back?If you are using the stock coil pack, running equal length wires is going to look horrible...
