1. Shmaako
    Shmaako Well-Known Member
    118
    19
    Aug 29, 2016
    Winnipeg, Manitoba, Canada
    Local Time:
    6:11 AM
    20200627_133053.jpg I got my new bushings etc from brewers and installed but its been years since I removed the z bar and I don't remember if it was crooked...Wondering if this is going to be trouble?
  2. valiantwagonguy
    valiantwagonguy Well-Known Member
    911
    612
    Oct 20, 2005
    Long Island
    Local Time:
    7:11 AM
    looks to me like you are using the wrong pivot ball plate on the bell . That shaft should be at right angle to the fender and the bell at the same time.
  3. HemiSSDart
    HemiSSDart Dartus Interuptus
    1,385
    939
    Feb 20, 2013
    Illinoisy
    Local Time:
    7:11 AM
    If this is a factory big block A-Body it looks like you are missing the spacer that goes between the ball bracket and the bell housing.
  4. Shmaako
    118
    19
    Aug 29, 2016
    Local Time:
    6:11 AM
  5. HemiSSDart
    1,385
    939
    Feb 20, 2013
    Illinoisy
    Local Time:
    7:11 AM
    So the car was a factory manual trans car?
  6. Shmaako
    118
    19
    Aug 29, 2016
    Local Time:
    6:11 AM
    No, I bought it and it was converted already. I wish I would have taken notice of how well it aligned when I took it apart.
  7. HemiSSDart
    1,385
    939
    Feb 20, 2013
    Illinoisy
    Local Time:
    7:11 AM
    So the ball stud reinforcement is in the correct location?
    • Like Like x 1
    • HemiSSDart
      1,385
      939
      Feb 20, 2013
      Illinoisy
      Local Time:
      7:11 AM
      Here is a picture of what it should look like. If you need the measurements I can get them on Tuesday.
      • Thanks! Thanks! x 1
      • Shmaako
        118
        19
        Aug 29, 2016
        Local Time:
        6:11 AM
        Bad pic but...No bracket at all...
      • HemiSSDart
        1,385
        939
        Feb 20, 2013
        Illinoisy
        Local Time:
        7:11 AM
        The bracket is on the outside of the inner fender just above the frame rail. Look at the picture I posted of the turquoise car above, that will give you a general idea of where it is supposed to be located.
        • Agree Agree x 1
        • Daves69
          Daves69 Well-Known Member
          4,965
          3099
          Feb 20, 2011
          WestOfChi
          Local Time:
          6:11 AM
          Looks like something was added there. May need to change the frame hole location and stock bracket. The Z bar should be straight across in any view.
          You might consider fan and firewall clearance if you by chance have the engine too far rearward.
          Mid page shows parts and exploded views in link below. Both sketches show the bracket 90° off. But a picture of the bracket below is correct.......
          Mopar Big-Block A-Body 4-Speed Conversion
          HemiSSdart picture is correct as well......
          • Shmaako
            118
            19
            Aug 29, 2016
            Local Time:
            6:11 AM
            With this BB I barely have room for error...as it is It looks as though I will have to shave a fin from the back of a valve cover to clear the blower motor. I don't want it further forward because it looks like I will need the room for my fan...
            Also, (perhaps a rookie question) doesn't the trans xmember set the front to back pretty close to where it has to go give or take?
          • Daves69
            4,965
            3099
            Feb 20, 2011
            WestOfChi
            Local Time:
            6:11 AM
            MT's on my 440. Plenty of clearance. Go to be a almost 1/4". :D
            Yeah it should. Then too, dealing with a conversion it's worth a look IMO.
            • Like Like x 1
            • matthon
              matthon Well-Known Member
              2,260
              500
              Aug 29, 2008
              Local Time:
              7:11 AM
              I swapped out my original bb linkage for all new stuff from Brewers.
              I had to modify the bell bracket to level it.
              Don't really know why, the only change was to an 18 spline trans.
              A855 - 5 Speed
