AdamR
Big Member
Copy and paste this format into the message window and fill in the blanks
Car
Weight
Gear ratio
Tire diameter
RPM through trap
MPH through traps
ET
Engine CID
Head Type
Valve size
Head Work
Cam Manufacturer
Cam specs at 50
Carb type and size
PV Rating
Jet sizes
Plug number and brand
Intake Manifold Type
Piston Make
Compression Ratio
Trans type
Trans Mods
Convertor type
Convertor stall
Trans Brake
Drive shaft stock or aftermarket
Initial timing
Total timing
Total advance at what RPM
Rear end type
Car
Weight
Gear ratio
Tire diameter
RPM through trap
MPH through traps
ET
Engine CID
Head Type
Valve size
Head Work
Cam Manufacturer
Cam specs at 50
Carb type and size
PV Rating
Jet sizes
Piston Make
Compression Ratio
Trans type
Trans Mods
Convertor type
Convertor stall
Trans Brake
Initial timing
Total timing
Rear end type
