Show Your Big Block A body!
there she is my 2 owner, 22k mile 69 formula s 383 auto b5 blue fastback.
Don't know how I overlooked this thread for years.
OK.....my other BB A body
Or are there no big block '65 Barracuda's in this thread? :sad7:
I didn't see any either, but not surprized because I understand you need one big *** crowbar to make one fit.
Ma Snart
Yeah, you did miss one; post 142. However, I guess I didn't post a photo of the engine in the car so here you go. Still in the process of building.
500ci 440 w/Max Wedge Port Stage VI heads. Lakewood Scattershield and 4-speed are behind it now. Plans to put a Quicktime bellhousing and Viper 6-speed later; you can see the 6-speed sitting by the right rear wheel well.
Ma Snart
Not really. I don't think it will be that bad once I remove the inner fenders and tie the roll cage to the front frame rails while tying into the upper shock towers.
Your rightbrad4406, I should have said a cutting torch and welder
Here ya go, almost there.
Thanks, don't think so, guess it's because of the frame rails that were used back when it was done. When it was done it had 33X21.5 x15 M/T on it, so the frame rails are close together too. They look a lot closer then they are in that pic.The slicks are 32X14x15 Goodyears.
Nice ride, what headers do you have?
Next year after my garage gets expanded, gonna put this (after a rebuild)
In this....
I'm tempted to leave it looking like a total POS and keeping the exhaust as quiet as possible :)
Here is mine
