68383GTS
I got a narrowed B Body housing with my Barracuda.It measures 51 7/8 from flange to flange.Will stock small bolt A Body axles fit this housing?
Thanks,Jim
Thanks,Jim
Thanks,Jim
You will probably need to slice a little off of each axle. 52 5/8" is stock A body width.
May end up a bit short on splines the way some are cut? I could get a dimension on these if you need it.
