T56MaxTorq
Well it's been a long long process to add boost to a little 318 in my duster but she is running and driving. Have a few things to correct like my fuel map and some interior wiring. I used FABO so much in this build and wanted to share.
Stock magnum 318 bottom end, honed
ARP rod bolts
EQ heads
Hughes roller rockers
Turnonetics 62-1 turbo
Tial 38mm wastegate
HKS blow off valve
Custom SS hot pipes I welded
Mild roller cam
Magnum air gap
44lb injectors
Megasquirt II controlling ignition & fuel
Edelbrock throttle body
Now for body work and street legal stuff.
ARP rod bolts
EQ heads
Tial 38mm wastegate
HKS blow off valve
Mild roller cam
Magnum air gap
44lb injectors
