Motoblag
After pulling most of the interior to do some electrical troubleshooting, I found the rear crossbracing to be broken on one side. Also, is this welded in chunk of metal stock? At some point in the car's ownership someone converted it to a 4 speed 340 from a 318 auto. I assume this plate is for the pinion snubber.
The passenger's side is loose:
Quality welding:
Should I prep the surfaces and plug weld the bracing in? Drill and bolt it together?
Quality welding:
