Nice combo would not take much to go high 12's. What color blue is the 'cuda?69 Barracuda
340 10:25 comp.
Direct Connection 474 cam
X heads
Headman headers 1 5/
Full 2 1/4" exhaust, Flowmasters
LD340 intake
Holley 3310 750 cfm
D.C. Electronic ignition
2800 stall converter
727 reverse manual valve body
Super stock springs, 383 tortion bars
3:55 geared sure-grip
Street radials, no burn out
2000 rpm take off
6200 rpm shift
ET 1/4 mile: 13:39 @ 103 mph
Thanks, that's an old school combo, proves sometimes less is better, the paint is what's left of an old Maaco supreme ; Imron metallic blue over an original B-5Nice combo would not take much to go high 12's. What color blue is the 'cuda?
Cudaj380
Looks good cudajThanks, that's an old school combo, proves sometimes less is better, the paint is what's left of an old Maaco supreme ; Imron metallic blue over an original B-5
So the car is unchanged this year. Last weekend I had it at the old time drags again. It was cooler than last year. The car ran an all time best of 13.29 @ 101 mph! Awesome.Well....I just got back from a weekend of drag racing. I managed to make15 1/4 mile passes over three days, all in the 13.4 to 13.5 range. The best was a 13.44 at 99.5 mph with a 60' of 1.8. Not spectacular but certainly respectable for a 4000 pound street car. I went as far as the semifinals before breaking out.
Here is a pic...... battle of the 55's
Ran my 55
Looks as good as it runs. <aj>
Congrads excellent combo. <aj>1973 Duster
Magnum 360
Compression: 9.0:1
Valves: 1.925/1.625
Cast heads
Cam: 288/292
M1 Single Plane intake
Holly 750
Factory "hi stall" converter (~2500)
904
8.25" rear with 3.55 Suregrip
Drag radials
Last week (6/6/18) averaged 13.4 all night (10 total runs). Fastest was 13.342, slowest 13.517
And won for the first time ever!
View attachment 1715186026 View attachment 1715186028
Here is my combo stock 360 MP .508 cam 3000 stall converter edelbrock RPM intake 750 Holley HP carb and 8.25 rearend 3.21 gear frame tied exhaust dumping at rear and M/T 255 drag radial best ET was 13.39 at 100 mph normally mid 13.40's car has full interior.1970 Dart Custom, full interior, 290 lb driver, weld in subframe connectors, stock E58 1974 360 .040 over, air gap intake with 750 cfm Edelbrock carb, stock smogger heads, double roller timing chain, .444 int/.467 exh, 288/298 degree duration cam, stock rockers, f TTI step headers, full 3 inch exhaust, tired 727 trans with stock convertor, 8 3/4 diff with 3.23 gears, Truetrac diff, adjustable pinion snubber, 245/60R15 BFG drag radials, 18 psi, best time 13.78 @ 100 mph. (13.80 to 13.85 @ 98 to 99 mph typically)
UPDATE: added headers and went "up" to 2.76 gears... LOL13.91 with a 1.94 60 ft. Tuning will continue.
- 360, lets just say stock everything except mild cam (.427/204@050 intake, .454/216@050 exhaust), and a 4bbl.
- Stock exhaust manifolds with 2.5 duals out the back
- Stock 904 and converter
- 2.45 gears open
- Car weighs 3240 no driver, no spare and 1/4 tank
Update here too! Different used 440 in it this year, it is healthier and has a slightly bigger cam. Also I added a 850 double pump. It now runs 12.8! Heading to the track again this weekend.Ran my 55
Your not just head'n back to the track, your head'n to the 12 second sticky post as well!!!Update here too! Different used 440 in it this year, it is healthier and has a slightly bigger cam. Also I added a 850 double pump. It now runs 12.8! Heading to the track again this weekend.
3558lbs race weight
Stock '71 340, + 484/284 hyd.
750DP, small tube hdrs
3500 stall, 3.55's, 8x26 slicks
stock suspension, rear leafs clamped
P/Snubber, stock front worn shocks
this was a '71 Cuda.
1981 Santa Pod raceway
road car at the time
13.18@101.7 = 308fwhp
Just to add to above for reference>
added a .590/312 solid purple cam
HStripD intake, 850DP
1.75" race hdrs
4200 stall, 4.30's
10x28's
Stock 2.02 heads and CR
max rpm 6400
12.38@108 = 370hp
COOL!!..1976 Dart Sport. Standard bore stock crank 360 with Keith Black flat tops, stock 1.88/1.60 j heads, lunati bracket master cam .480/230, Chinese air gap intake, Holley 770 street avenger vacuum secondary, 727 with manual valve body and b&m 2400 converter, 1 5/8 headers and 4.10 sure grip. Best of 13.77@100.
