I think i repaired mine.That's it thanks Karl!
View attachment 1715396550Still want oem if possible though.
I use Karo Syrup in my Zinc Plating mix, it helps bring out the shine in the finish.
Lol . . .
For Real !!!
Weren't you happy with your service ???![]()
Had a body control module go nuts in a caravan. Horn honking, wipers activating.
Body control is in driver’s door.
Wires in door jamb broke and were giving bcm bad information.
Saw this 3 times so far.
Nasty storm is brewing.
Shouldnt be long and the power will go out. Hope not, generator is too far away to drag over in pouring rain.
blurry screenshot off local news, NBC
I changed the battery January 2018. Around that time it did some freaky stuff with windows not working at times. I think the horn blowing started sometime after that. Wondering if when old battery was dying it got its brain scrambled a little. Guess I will see when I put the module back in. Lately it would go a day or 2 after putting horn fuses back in till it would start blowing.Touching the battery cables together with the battery out diffuses the capacitors inside the computer and resets it to a basic level, then you take it out and drive it and it relearns your driving habbits and adjusts accordingly.
Want good grounds from engine to chassis, can even add an additional one. Stray voltage will make your car computer do crazy things, make sure all wiring is well insulated and not chaffing up against some sharp edge, even the high energy spark plug wires feeding back into the system. We are talking mili-volts here, electricity follows the path of least resistance to get back to the battery.
All connections clean and good, not green with corrosion, battery cables clean too. Test your battery want at least 12.5 volts, it is the heart of your whole electrical computer system.
I have found that inside the ECUs the capacitors start to leak over time, drain down on to the boards and now the electricity follows a new path goofing everything up. Rebuilders replace the capacitors, clean the boards, and reseal the boards with a clear sealer when all done.
The hard part is finding the good people to do this work.
Want to get them out of there close down the cell network!Ahhhh .. Late summer in the southwest deserts. When the girls can be scantily clad night or day.
Good thing they didn't choose the winter solstice for this event, they all be wearing parkas.
Same here easy to do Bill
Zinc Plating with Common Materials
What is this a picture of ? Zinc plating mix ? Do you mind telling a little about it ?
Bill
Trunk is painted, not Zinc coated. Looks good...
