Oh I have a degree wheel, I just didn’t use it. It sits over on that shelf with all the other tools I’ve never used.
Well, today’s the big day! Dropping in the motor. Pops is coming over to help, and hopefully with his oversight, he’ll make sure I don’t forget anything.
Better check your inbox quick Righty Tighty.
Haha! Well, I've heard the lecture all my life....you'd think I would've learned by now! I'll be honest, I didn't replace the main seal because I didn't want to pull the crank. But after I had everything put together, I realized I could've replaced the seal without pulling the crank. The learning continues...And here I thought my son was the only one I had to regularly lecture about the price of shortcuts LOL
Well, you did prime the engine so got some oil back in that seal area. But it ought to drain out of some holes in the rear main cap and not build up around the main seal itself.....
Looks good. I just pulled my engine and trans. Did trans first then engine. May try putting them back in together, but I don't have a lot of help around here.
You are going to want to wrap the trans cooler lines or you will be adding a lot of heat to the fluid, I think.
Sure. Or look up heat wrap on Summit or Amazon. There are a lot of options that might better fit the smaller tubes. If you are wrapping the headers, I'd still wrap the tubes. That pipe is really close to the oil pan which doesn't help either.I did think about that. I have some header wrap coming that I was going to place in strategic areas, and I'm going to reroute the speedo cable. Could I wrap the trans cooler lines with the same header wrap?
So then u didn’t have the spacers in the mounts last summer? U will have to check and see how much room u have to raise the tranny. Kim
