Hello everyone. I’m looking for opinions on shop floor drains. My initial plan was using 4 12x12 basin drains (marked by the red circles) but I’ve been debating if I’d be better off doing two long trench drains (blue) or maybe a trench drain on the right and the basins on the left. For a little more info on the planned layout of the shop the top right corner will likely be where I park my truck, so I’ll definitely want a drain in that area. I’ll be installing a 2-post lift (yellow) and don’t want any type of drain directly under it for any spilled oil to run into or to interfere with the wheels of a oil drain pan or engine hoist which is why I have the basin and/or trench drain stopping short of the lift. I would still slope the lift area floor toward the drain, that way if I want to wash out the underside of a vehicle on the lift, it’d drain out.
For the left side of the shop, I’ll also eventually be buying a movable 4 post lift which will probably be in the top left section of the picture and a rotisserie in the bottom left corner. Any body/paint work I do will likely be in the bottom left corner as well, so having a drain there will be nice to be able to wet the floor down before painting to keep dust to a minimum.
I did already buy the basin drains but have been having second thoughts and may take those back.
Thoughts?
Thoughts?
