NC Engine Builder
Grumpy Old Man
- Joined
- Oct 10, 2008
- Messages
- 6,668
- Reaction score
- 9,997
It can, especially with a ham fisted approachThat's great to know. Thank you! Does the mandrel-type bearing install tool distort the bearings or something?
That's why I use a 28oz Snap On ball peen and use soft blows. Lotsa weight and a soft touch.It can, especially with a ham fisted approach
Both the factory magnum dampers I have currently in my stash have the same timing marks. It’s rather normal.
In his build thread the pictures show lack of LA oiling holes to the heads. There is no doubt that is a Magnum block and was no way ever used as an LA build by Mopar.The engine that the red balancer came from was a Magnum. It had the Magnum intake pattern, the rocker arms on studs, the different balance factor but....NO casting date. Instead, they had a weird coded stamping below the left head on the front. A "1" in the stamping indicated a 1991 or 2001. I assumed it was a 1991. The engine actually belongs to FABO member @RBConvert , we are rebuilding that engine at the same time we are doing mine, both here in my backyard shop...
The engine was standard bore. The machinist confirmed it. That is why I thought it might have been an early production 5.9 that was pulled from stock and used in the Mopar Performance crate 360 program.
I could be wrong about the history but being standard bore, it was never a junkyard engine.
It surprised me too. I remember hearing and reading that MP used "seasoned" (a fancy name for an engine pulled from a junkyard) blocks and bored them .020 over. When the machinist measured it and found standard bore, we all were surprised. We thought the used pistons might be worth something to sell but who ever needs a standard piston when doing a rebuild?I wonder how many of those were built? Or where they came from? Were they service replacements, rebuilt and diverted to the MP program, Junkyard like you said? Picked off the line? There's no 7 digit casting number -dash CID on the driver side or casting date on the passenger side in line with one just above the freeze plugs? I remember the MP catalog at least at one time described them as 20-over and "seasoned blocks" which most likely says used then rebuilt/remanned. Maybe they weren't all that way?
There were many different variations of the crate engines and short block assemblies from Mopar.It surprised me too. I remember hearing and reading that MP used "seasoned" (a fancy name for an engine pulled from a junkyard) blocks and bored them .020 over. When the machinist measured it and found standard bore, we all were surprised. We thought the used pistons might be worth something to sell but who ever needs a standard piston when doing a rebuild?
