CLAY72dart
Alright here is how my story goes I have a 67 318 with 318 heads and a spare set of 360 heads practically stripped to nothing all I know I need is valves to put these on pictures below are of the cam kit I have in a box for the car and the cam spec sheet. Looking for advice I’m keeping the stock crank and connecting rods other than that it’s free game. Ignore the pushrods didn’t know enough when I bought that about a year ago. I’m thinking I can use the original pushrods and rocker assembly on the 318 heads but I’m not sure I don’t have a spec sheet for something like this.
These are the 360 heads with nothing on them
This is the 318 heads I have with everything on them.
Intake. Exhaust.
Don’t know what this chart really means. But this is what I bought a while back on marketplace.
Looking for help on what to buy to build the block I can answer your questions If you can help me choose what to do to make some power.
Intake. Exhaust.
VALVE ADJUSTMENT | HYD | HYD |
GROSS VALVE LIFT | • 497 | . 483 |
DURATION @ | ||
- 006 TAPPET LIFT | 287 | 304 |
VALVE TIMING .006 | Open | CLOSE |
INT: 40.0 | BTDC | 67.0 ARDC - |
EXH :80.0 | BBDC | 45.0 ATDC |
THESE SPECS ARE FOR CAM installed | ||
@ 102.0 INTAKE CENTER LINE | ||
INTAKE | EXHAUST | |
DURATION @ . 050 | 235 | 249 |
LOBE LIFT | • 3310 | • 3220 |
LOBE SEPARATION | 107.0 |
