Totally unnecessary for a Super Six conversion. Just use a stock Super Six intake.I meant one of those Aussiespeed AS0023 long runner ones.
Or a short runner Aussie Speed two or four barrel intake, if you can't find a stock super six intake. Or even a Offie 4 bbl with a 2bbl adapter.Totally unnecessary for a Super Six conversion. Just use a stock Super Six intake.
Be nice if you'd show some pictures of the base. That way, maybe some of our lesser of fabricators (like me) might get some ideas on how to modify theirs.I never understood the requirement to use the "Super Six" air cleaner housing. I was able to modify my original single barrel carburetor's air cleaner to work on the Carter two-barrel carburetor when I installed the Super Six setup. i just peened the part of the air cleaner that touched the choke plate butterfly linkage for clearance. Slant Six Dan might know the reasons why you need the Super Six Air Cleaner housing. I have been running mine for 20 years without any issues.
My 2 cents...................
Thanks for the pics! Doesn't matter if it's a 318 carburetor. They are physically the same size as the Super Six variant as far as the air cleaner.I should have mentioned before that I'm running an early to mid 70's 318 two-barrel carb. I apologize for any confusion.
the newer version the "tin top" BBD. Those came out in around 74-75ish.
That's what I did on my '62. I was never happy with how the weld itself came out (sloppy/ugly) but the graft job did work. Make sure to take a big enough circle out of the donor 2bbl air cleaner to clear all the sticky-outy parts* near the top of the carb.I have a 60's "super 225" air cleaner I wanna use for mine, I was just gonna cut the center out and then cut the center out of one of my (scrap) 318 lean burn air filter housings and MIG the 2 together...
Dan, I do understand what you are saying about cutting the air cleaner/air horn ring. However, there is no light visible between the modified air cleaner hole and the air cleaner gasket when installed.
the carburetor has stayed clean
I didn't like the look of the "Super Six" air cleaner housing especially on a 65 Valiant.
The "tin top" BBD, was that the one that had the flat metal plate that attached with one screw, over the metering rod adjustment assembly? And no rods or linkage went through the flat metal plate?The "solid fuel" BBD. Came out for '77.
Nice job man !!!!Dan, I do understand what you are saying about cutting the air cleaner/air horn ring. However, there is no light visible between the modified air cleaner hole and the air cleaner gasket when installed. I don't drive the car that much, but the carburetor has stayed clean throughout the years. I didn't like the look of the "Super Six" air cleaner housing especially on a 65 Valiant.
As always, your input is invaluable.
