Jeff Seighman
aka jeffnmo
I've said it before and I'll say it again, it's gonna be a BEAST.
Yes sir you Jeff. Thank !If you're talking about me, yeah, I like cats. I like what you're doing with that 70 Dart to.
It's going to take some getting used to that's for sure.I've said it before and I'll say it again, it's gonna be a BEAST.
Yes, I'm going to take them into work and resize them. The wear is showing them a bit out of round.Good catch on that rod bearing!!
Some bondo will smooth it right out;)More welding today, had a hell of a time trying to get a puddle started today, every time I tried to add filler, it would just ball up .
So after 2 hours of farting around with my torch cooler (redneck tile saw pump 5 gallon bucket)
I sat back down and tried again, I was able to get some welding done, equal amount on both sides, I think it's close to 3/4 inch deep now...1/2 inch to go and I will have enough to port a true taper.
So sorry if this offends any of you trained or certified welders lol.
I have a gallon of splash zone to use for the rest of the runners.....this is going to be real pretty lol.Some bondo will smooth it right out;)
I tried something, it didn't work. Yes Dyno time only. I wanted to run a tad tighter clear.That #7 rod bearing, did it only have dyno time on it? What was the clearance when it went together?
So I learned I was a few tenths too tight by 3.
I think #7 looked especially bad because what was above it. The rear cam bearing somehow looked really bad and was at steel. I'm not sure what went on there but it will be figured out and remedied.
Main bearings looked good except for a little bit of **** probably made it's way onto the surface.
Going back to standard size king coated bearings.
.019What was the clearance? I forgot.
Hopefully you were using some of Tim’s 0w10 synthetic (or whatever magic sauce he uses) with the clearance that tight..019
Nope lol. 30 grade vr1Hopefully you were using some of Tim’s 0w10 synthetic (or whatever magic sauce he uses) with the clearance that tight.
Are you having Tim do the finish work to make it pretty.I have a gallon of splash zone to use for the rest of the runners.....this is going to be real pretty lol.
He said he was getting it done next weekend lolAre you having Tim do the finish work to make it pretty.
Has he done any of the body work yet, he should have had that ready for paint by now. lol
