Well here is what I was up to today. Time to put the poly bushing in the leaf springs.
Here is how I get the old bushing out. I take a long drill bit and drill down between the rubber and metal.
The drill bits walks around the bushing and pulls it out
Here's the leaf springs with there new poly bushing installed and all painted up just waiting to go back under the Dart.
This work for the other end also, you just need to drill around the metal insert in the middle first. Use some wd 40 as the drill is walking around the insert then pound it out with a punch. To get the rubber part out just do like in the first picture. Works really good!
