Currently I have a Hughes 10" 24-30 pro street converter (3000 stall). I'm wanting to go somewhere between a 3500-4000 stall. Before, when I put the trans in gear, the RPM really dropped and I was always putting the trans in neutral just because I didn't like it idling very low. Due to the fact that I'm going with a larger cam than before (~ .650" lift) and want to eliminate this issue, I'm shooting for very little to no drop in idle RPM and also have higher rpm launches.
So I call up Hughes and they said that by the time they change the stall on mine, I'll be close to what a new one would cost. They recommended their 24-40 10" converter that has a 4000 stall. That seems pretty high to me for some street use, but that's besides the point I'm getting to. What got me was he said "You'll new a new pump side". I didn't want to look the fool of course because I had no idea what he meant so just said "ok". I can only assume he meant that I needed to change the trans pump out, but why?
