512Stroker
We are all here because we are not all there.
How do you tape a streaming service?I taped it and will watch it this weekend. Can't wait.
I have been trying to figure that out for a while.
Okay, let me rephrase. I give my email to friends. I have learned the hard way not to give it to ANY business.What's the point of having email if you don't give it to anyone?
Thats why i asked, lol. Guess they wont be getting fifty bucks from me either!and they won't be giving you access to motortrend online..lol
Sorry if I misled you but I get it through my cable provider and tape off of that.How do you tape a streaming service?
I have not tried this but it may work. Connect your pc to your tv with a hdmi cable and hook up your recording device to the tv and record. Hope it helps.How do you tape a streaming service?
Pretty eye opening. 440-6 VS 426 hemi. Similar builds with same camshaft.
Sorry man. 525 ft lbs from a basically stock 440 6 pack ain't happening. And a Hemi has a LOT more torque than a wedge motor. You can even tell he can't even lie just look at his face. And yes I've dynoed 440's, 6 packs, Hemi's, 396's and 427's back in the day.basically told you everything people were saying for years.. the 440+6 is a better street motor then the hemi because of all the low end grunt.
You still have black and white tv? Dial phone? You should get rid of internet. Scary place. Hey, even the ice man gave up selling ice and opened an appliance store.Do they take checks? I dont buy ANYTHING on line, i dont give anyone my email, and i dont give anyone my credit card number unless i am speaking to an actual human at a business that I called.
You trust everybody on the internet? Good luck with that. I dont.You still have black and white tv? Dial phone? You should get rid of internet. Scary place. Hey, even the ice man gave up selling ice and opened an appliance store.
I don't trust everybody, period. But millions of people have done okay with internet, etc.You trust everybody on the internet? Good luck with that. I dont.
I looked at what motor trend collects, and keeps, and gives out about their subscribers. No thanks.
I'll give you a hint. One of the motors did better than the other.So what was the result?
I HIGHLY recommend Streaming Motor Trend. I watch it all the time.Here is the link for the fathers day $3/month special Stream Automotive Shows and Live Races | Motor Trend (motortrendondemand.com)
Why don’t you believe it? A basically stock 440-6 with a cleaned up set of heads, valve job, and a much more modern cam. Seems about right to me. And to further make the point, nicks garage dynod a completely stock 440-6 and it made 464lb/ft. So not very hard to believe if you ask me.Sorry man. 525 ft lbs from a basically stock 440 6 pack ain't happening. And a Hemi has a LOT more torque than a wedge motor. You can even tell he can't even lie just look at his face. And yes I've dynoed 440's, 6 packs, Hemi's, 396's and 427's back in the day.
The test was flawed because they used the same cam. If you were comparing a /6 to a hemi would you use a 1bbl carb on both ?
I have owned a killer 440-6 and driven a like new well tuned 426 Hemi Cuda.
The 440-6 was right now power while the hemi never stopped revving.
The 440-6 had ported 915s , .550 solid roller and headers... the hemi was stock. I gaurantee that with headers and a roller cam the hemi would have been much faster .
Also find 525 f/lbs a bit hard to believe, for either engine. Original 440-6 was rated at 490, Hemi also at 490 but at higher rpm.
.484/284 I believe was stock hemi grind
Back in the "day" the hemi vs 440 with same rear, all good tune, and in same equipped model, in the quarter typically were neck and neck to the end of the quarter, the hemi would outrun the 440.
Your results may vary!
And obviously the 440 is a more friendly street motor to the average gear head.
If you re not an "average" gear head, you may do better!
