100 shot of nitrous on 360 magnum engine
Who didn't like turning on three units all manually back in the 80's... LOL One on the shifter, horn button and dimmer switch. Kept a person busy.
What's a WOT safety switch? Didn't have those either. Used to drive it with the throttle instead of on/offing a button. Too easy to notice a car dropping 100+ hp blipping the switch..
1981 i went for a ride in 396 nitrous camaro
i bought a kit 2 days later marvin miller i think it was 299 bucks later it tested the lowest hp by hotrod i think of 4 kits 85 hp top kit was 120 ish hp think it was NOS they said the miller kit wasnt suited to the intake maybe blah.
68 dart 270 taxi package my 1st car 318 headers 2 barrel 727 8/3/4 3.23 sg 489 housing g-60s cragars air shocks as purchased 900 bucks
upgrades
spring clamps adjustable snubber offy dual port 360 holley 600 vac secondary 340 2.02 j heads mallory dual point street hemi 471 474 cam shift kit it was a dog until 3500 that cam sounded great in the 318
the nitrous gave it bottom end surprised alot of cars after that install
i put on a torker 340 single plane with the nitrous back then its what the smarter then i recommended
T to factory fuel line
momentary switch on carb at full throttle
switch on dash
holley fuel pump
ive run it on 2 a bodys
Delivered by ups came with a full bottle on those days lol
I did put the 100 shot of nitrous on my Duster, at Irwindale dragstrip, which is an 8th mile, the car went 7.22 at 93 miles an hour with a 1.53 60’.
I would strongly suggest that you wire in a NOS mini progressive (about $200), if anything for the RPM window switch capability. Add a WOT switch between the controller and the activation button for the kit and you will be good to go.
That's what my machinest said too
He said controller to dial back timing
He gappped my rings for it and said don't go crazy you will be fine.
Was also told run a dedicated pump from a small cell with high test fuel like 110 with lead to feed it.
My 2 plates for front and rear carbs of my Holley Cheater have small jets and work up. Has 3 levels of jets. Note) Center carb gets no plate, it gets spacer since you are only using it under WOT when the outboard are open.
That s what my machine said too
He gap my rings for it and said don't go crazy you will be fine.
Was told run a dedicated pump from a small cell with high test fuel like 110 with lead to feed it.
I control timing with the MSD box. It is hard on the car to burnout and stage with 25 deg total advance. If you run 30 ish for a 150 shot it isnt too bad.
And to the naysayers on the progressive...what else has remote bottle pressure, delay adjustable window switches, etc. for that price? It's not about the progressive function. Its about simplicity in wiring and making sure bad things dont happen unexpectedly. Just one guys opinion : D (from 2023)
You’re kidding right? Most EGT thermocouples are too slow to be worth much.
Interesting comment. I have an EGT readout as part of a tuner on my diesel pickup, but I haven't paid attention to response speed. Next time I drive it, I will study.
I think that if I buy something as a tuning aid for my bracket car, an O2 sensor with some sort of recording capability would be more useful.
You won’t be able to see the response speed via a gauge. The gauge will have a much slower response time than the actual thermocouple will. Most of the aftermarket egt probes are in the 140 millisecond range.
