Others have mentioned, make darn sure the fuel supply is sufficient. Better to have too much supply and dial it back, than not enough.
Exhaust gas temperature. You don’t need to monitor EGTs on a street car with 100 shot.
I think the OP would change his mind after most everyone insists he installs: air fuel meter, EGT meter, progressive nos controller, separate fuel pump, seperate gas tank, timing controller, specially wired battery bottle warmer and everything else!!!!!!! Freaking A people. I bet if he calls holleys tech line they will advise that you do not need all that crap for a FREAKING ENTRY LEVEL Powershot system!
Allow me to retort,I suggested what I did for safety and ease of use. If you don't think you need a window and WOT switch on a nitrous car you are an idiot or don't have much experience with nitrous.
And if you do....show your cards or stfu
1) Progressive supplies safety measures above.
2) AFR monitor is a good thing, refer to my last statement before the list.
3) A bottle warmer is necessary to keep the tune up in check. If you don't understand this refer to the last statement before the list.
4) A stable fuel supply is also necessary to keep the tune up in check. Refer to the last statement before the list LOL.
Some of you armchair quarterbacks are really funny with your internet experience.
A lot of people are making some good points here for safety and tuning etc..I think the OP would change his mind after most everyone insists he installs: air fuel meter, EGT meter, progressive nos controller, separate fuel pump, seperate gas tank, timing controller, specially wired battery bottle warmer and everything else!!!!!!! Freaking A people. I bet if he calls holleys tech line they will advise that you do not need all that crap for a FREAKING ENTRY LEVEL Powershot system!
Having said that, when I installed my first kit back in the 80's , all I bought was the adjustable kit, a Holley blue, some wire, a micro switch for the carb, an arming switch, points switch and relay and a twin point dizzy conversion plate so I could switch between one set of points to the other to retard the timing. Plus a spare pair of underpants.
I think you have more in that combo than 12.8's. However, most stock blocks will handle a 100 shot, but that "extra 100 hp" on top of the already "extra hp" of stress will shorten the life of a stock bottom end
You cant have enough insurance when using nitrous !!!It's only (solicited) advice offered from people running nitrous on their vehicles...he's free to ignore or disregard based on his application...
Wise and well spoken.To be perfectly fair, if I were installing ONLY a 100 shot on my own vehicle, I probably would forego some of the items brought up in this thread (EGT probes, separate complete dedicated fuel system, progressive controller). But, having experienced the difference between N/A vs boosted/sprayed, I'm pretty sure eventually, I'd wanna put in bigger pills and not running any safeties/upgrades with increased amounts of nitrous-just like with boost-is asking for a failure. So the other suggestions, like AFR monitoring equipment, timing management, proper tuning, dropping a heat range or two, increased fuel delivery...those are all requirements for a successful implementation of power adders based on what experience I do have.
Yes, I know...people (trailblazers) did it decades ago, and they laid the path for all of us to follow and execute, but glossing over or ignoring the damages they experienced in search of lower ETs as just part of the journey really disregards the fact that most of us don't have disposable mountains of cash if a set of rings checks out or all the exhaust seats get fried from A/F going out for a couple seconds...I'd much rather spend a few hundred on the front side for some extra gear to keep processes in check rather than a couple thousand and/or the downtime required to fix all the breaks after I put the spurs to it...YMMV
But as we all know once the 100 shot is on it wont be long until you want more....then...more....you will become a nitrous junkie...lolTo be perfectly fair, if I were installing ONLY a 100 shot on my own vehicle, I probably would forego some of the items brought up in this thread (EGT probes, separate complete dedicated fuel system, progressive controller). But, having experienced the difference between N/A vs boosted/sprayed, I'm pretty sure eventually, I'd wanna put in bigger pills and not running any safeties/upgrades with increased amounts of nitrous-just like with boost-is asking for a failure. So the other suggestions, like AFR monitoring equipment, timing management, proper tuning, dropping a heat range or two, increased fuel delivery...those are all requirements for a successful implementation of power adders based on what experience I do have.
Good stuff here Induction Solutions
Really like the boogie box setup...it does it all Boogie Box NPC-1006 Progressive Nitrous Controller - Induction Solutions
That's how I'm gonna use it. My old crate won't hook up an extra 150 or 200 hp at the starting line.Yup, I started at 150, then 175/200/225 than the top at 250. The old low compression 440 made 100 runs with the 250 shot. Used it as soon as I shifted to second gear. Kim
Some of the new electronics are great, you might not hook with 200 shot at the hit but with a progressive controller you could hit it with 25% at the line and ramp it in based on traction. The sky is the limit nowadays.That's how I'm gonna use it. My old crate won't hook up an extra 150 or 200 hp at the starting line.
