All my window and door mechanisms are installed. I still need to apply the window tint to the door and vent window glass and to the tailgate glass.
Good job Don! It's a little tricky but nice to have it done.All my window and door mechanisms are installed. I still need to apply the window tint to the door and vent window glass and to the tailgate glass.
Anyone knows if the rubber cover that should be mounted here are being reproduced?
Thanks! I will check with him.
Thanks Don, now I know what to search for!I did find the section in the parts book about the glass including the quarter window glass. It leads me to think that Dart and Valiant Cv Cp is the same for both as only one part number is listed for clear glass and another for tinted and make no differentiation between Dart and Valiant
Does he still grind them? That might be the ticket for me!!Ulf. Very Nice. Mine was 40 over as well. Don introduced to Jim regarding the cam shaft which Jim set up a bit more than the stock Hipo. Very Lively when I put my foot in it. Just plain fun. Looking good. sgrip65
I will this weekend! I've been involved with the WRC Rally Sweden. What a great race! Those special WRC cars were great but I loved the historic race cars.As far as I know he does. I’ve heard that he’s slow on the roller cams; don’t know if he’s slow on the flat tappet cams. PM me with all your engine specs, transmission, rear end including gear ratio and any specs you can provide on the car and I will give him a call for you. He only works in the afternoon about 3 to 7 or 8
Started tonight to take apart the valve train. They were extremly greasy to start with.
Why do they get in this condition?
So true! Must be some kind of chemical thing with the oil I guess.I would suspect lack of maintenance
Not on this one but on the Dart Charger I'm working on.Will you be using a fan shroud?
I can disassemble the factory unit for you, aka "clean the inside"! Or simply just remove the arm!I guess I will have to use a fuel pump block off plate since I will be using an in-tank electric for the Sniper. I would love to have a dummy fuel pump for the more or less stock motor/engine compartment appearance m.
