there all in Texas
thank you, as soon as this cold front moves out I will get back at it, thank you very much for all you do to keep me moving forwardNice work Mike!
Did some wrestling with the Hookers yesterday for a mock up and test fit
when you said I would regret it it stuck, and thank you very much, that was the motavation I needed , thank youOh cool, so you decided to use them? You will not regret it.
thanks. I will, and I seen the chrome one on another 66 273 and I will for sure do that as well , memike is tired, Yall have a nice evening and thanks to all of you again, I will sleep well tonightThanks for the thanks Mike! IMO I would swap PC and oil cap side to side. Would be nice to see the PVC chromed. But that's my opinion. I plan on putting a chrome one on my sb. For me the little bit of chrome helps set it off.
Very nice Mike and I hear ya about the cold....-35*C tonight! Dammit....
Let me double check that and get back to you, @66340SEDAN did say if we run a to wide of a rim it will touch on hard left hand turns, I will check, that is a 15 4" wideWhat size front wheels and tires you running, Mike? Do you get any rubbing against those headers?
there all in Texas
Um, is that an egg?My rims are 15x4.5 and with a 5.60-15 tire and drive nice and no running...just have to take it easy in the turns with the narrow tires.
Um, is that an egg?
It does beg the question,Lmao. Good eye. "Barn find"?
Um, is that an egg?
If you don't color 'em, eggs are easy to hide in the snow.Yes...and there are 2.... had an Easter egg hunt for the kids in the shop last year, we had a snowstorm and it’s no fun hiding or searching for eggs in the snow...
Thanks for dropping in brother Keith, can I ask a question ? Have you ever had to pull the engine in your valiant with the Hookers in ?My rims are 15x4.5 and with a 5.60-15 tire and drive nice and no running...just have to take it easy in the turns with the narrow tires.
thank you very much for your time and help, I know witch one you are talking about, will doI found that that small curved section that goes on the driver side that slipped into the headers vibrated loose after a few years And would rattle, so I tack welded it in place
